U-boot failed to mount rootfs using nfs. Procedure
The nfs on my board and the computer have been self-looped and all are fine, and can ping each other
The parameters for bootargs to enter the kernel boot are set as follows
setenv bootargs  root=/dev/nfs rw nfsroot=192.168.9.119:/nfs/rootfs,v3 console=ttyS0,115200
Added v3, then
ext4load mmc 1:1 0x84000000  /boot/Image
ext4load mmc 1:1 83100000   /boot/tegra210-p3448-0002-p3449-0000-b00.dtb
booti 0x84000000 - 83100000
However, after reset, I cannot access the system where my network file is mounted
我板子和电脑上面nfs都自环测试过了全都是没有问题的,也可以互相ping通
bootargs进入内核启动的参数是这样设置的
添加了v3,然后
但是reset后一直都进入不了自己的网络文件挂载的系统
他的日志是
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] kernel updata success ...
[    0.000000] Linux version 4.9.299-tegra (zzy@Ubuntu22) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #6 SMP PREEMPT Fri Jun 23 07:46:15 CST 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: root=/dev/nfs rw nfsroot=192.168.9.119:/nfs/rootfs,v3 console=ttyS0,115200 init=/linuxrc ip=192.168.9.9
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 30492(93%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3575404K/4159488K available (15422K kernel code, 2970K rwdata, 6644K rodata, 8640K init, 614K bss, 108948K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f90000   ( 15424 KB)
[    0.000000]     .rodata : 0xffffff8008f90000 - 0xffffff8009620000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009620000 - 0xffffff8009e90000   (  8640 KB)
[    0.000000]       .data : 0xffffff8009e90000 - 0xffffff800a176808   (  2971 KB)
[    0.000000]        .bss : 0xffffff800a176808 - 0xffffff800a21032c   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] PLL_RE already enabled. Postponing set full defaults
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001714] Console: colour dummy device 80x25
[    0.001735] console of kernel starting
[    0.001743] kmemleak: Kernel memory leak detector disabled
[    0.001765] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001779] pid_max: default: 32768 minimum: 301
[    0.002231] Security Framework initialized
[    0.002452] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002461] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003566] ftrace: allocating 47250 entries in 185 pages
[    0.173839] ASID allocator initialised with 65536 entries
[    0.211564] tegra-id: chipid=22117.
[    0.211585] tegra-id: opt_subrevision=0.
[    0.211604] Tegra Speedo/IDDQ fuse revision 4
[    0.211611] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.211617] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.211624] Tegra: CPU Speedo Value 2046, SoC Speedo Value 1952, GPU Speedo Value 2057
[    0.211629] Tegra: CPU IDDQ Value 1612, SoC IDDQ Value 1848, GPU IDDQ Value 2240
[    0.211651] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.211666] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.211676] DTB Build time: Jun 23 2023 07:43:53
[    0.261059] CPU1: Booted secondary processor [411fd071]
[    0.292980] CPU2: Booted secondary processor [411fd071]
[    0.324941] CPU3: Booted secondary processor [411fd071]
[    0.325027] Brought up 4 CPUs
[    0.325046] SMP: Total of 4 processors activated.
[    0.325056] CPU features: detected feature: 32-bit EL0 Support
[    0.325323] CPU: All CPU(s) started at EL2
[    0.325342] alternatives: patching kernel code
[    0.333514] devtmpfs: initialized
[    0.371206] Initilizing CustomIPI irq domain
[    0.371522] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.371545] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.382134] pinctrl core: initialized pinctrl subsystem
[    0.383100] regulator-dummy: no parameters
[    0.383367] Initializing plugin-manager
[    0.383518] Plugin module not found
[    0.383689] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.383697] Error in parsing node /plugin-manager/fragement@0: -22
[    0.383826] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.383831] Error in parsing node /plugin-manager/fragment@1: -22
[    0.383965] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.383970] Error in parsing node /plugin-manager/fragment@2: -22
[    0.384102] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384106] Error in parsing node /plugin-manager/fragment@3: -22
[    0.384240] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384245] Error in parsing node /plugin-manager/fragment@4: -22
[    0.384379] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384384] Error in parsing node /plugin-manager/fragment@5: -22
[    0.384514] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384518] Error in parsing node /plugin-manager/fragement@6: -22
[    0.384649] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384653] Error in parsing node /plugin-manager/fragement@7: -22
[    0.384783] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384788] Error in parsing node /plugin-manager/fragement@8: -22
[    0.384920] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.384925] Error in parsing node /plugin-manager/fragement@9: -22
[    0.385093] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385101] Error in parsing node /plugin-manager/fragment@12: -22
[    0.385238] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385243] Error in parsing node /plugin-manager/fragement@13: -22
[    0.385389] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385393] Error in parsing node /plugin-manager/fragment-e2614-common@0: -22
[    0.385526] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385530] Error in parsing node /plugin-manager/fragment-e2614-a00@1: -22
[    0.385662] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385668] Error in parsing node /plugin-manager/fragment-e2614-b00@2: -22
[    0.385798] chosen/plugin-manager does'nt have ids, nct and odm-data
[    0.385804] Error in parsing node /plugin-manager/fragment-e2614-pins@3: -22
[    0.388524] NET: Registered protocol family 16
[    0.392504] pstore: using zlib compression
[    0.393107] console [pstore-1] enabled
[    0.393116] pstore: Registered ramoops as persistent store backend
[    0.393126] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.409082] cpuidle: using governor menu
[    0.412302] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.413758] vdso: 2 pages (1 code @ ffffff8008f97000, 1 data @ ffffff8009e94000)
[    0.413789] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.417408] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.419781] Serial: AMBA PL011 UART driver
[    0.420299] tegra_powergate_init: DONE
[    0.420322] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[    0.420336] DTB Build time: Jun 23 2023 07:43:53
[    0.422296] Tegra reboot handler registered.
[    0.426771] iommu: Adding device tegra-carveouts to group 0
[    0.426909] platform tegra-carveouts: domain=ffffffc0f9b13f18 allocates as[0]=ffffffc0f94480a8
[    0.427264] iommu: Adding device smmu_test to group 1
[    0.427324] platform smmu_test: domain=ffffffc0f9b22198 allocates as[0]=ffffffc0f9448110
[    0.428136] mc: mapped MMIO address: 0xffffff8008041000 -> 0x70019000
[    0.428198] mc: mapped MMIO address: 0xffffff8008067000 -> 0x7001c000
[    0.428255] mc: mapped MMIO address: 0xffffff800807b000 -> 0x7001d000
[    0.428270] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.428290] mc-err: mcerr ops are set to t21x
[    0.438943] iommu: Adding device 70090000.xusb to group 2
[    0.439237] iommu: Adding device 70006000.serial to group 3
[    0.439295] platform 70006000.serial: domain=ffffffc0f94ba858 allocates as[0]=ffffffc0f9448178
[    0.439722] iommu: Adding device 70006040.serial to group 4
[    0.439996] iommu: Adding device 70006200.serial to group 5
[    0.440190] iommu: Adding device sound to group 6
[    0.440251] platform sound: domain=ffffffc0f94bad98 allocates as[0]=ffffffc0f94481e0
[    0.440834] iommu: Adding device 7000d400.spi to group 7
[    0.441170] iommu: Adding device 7000d600.spi to group 8
[    0.441513] iommu: Adding device 50000000.host1x to group 9
[    0.441798] iommu: Adding device 54080000.vi to group 10
[    0.442198] iommu: Adding device 54600000.isp to group 11
[    0.442453] iommu: Adding device 54680000.isp to group 12
[    0.442728] iommu: Adding device tegradc.0 to group 13
[    0.442786] platform tegradc.0: domain=ffffffc0f94d2b58 allocates as[0]=ffffffc0f9448248
[    0.443230] iommu: Adding device tegradc.1 to group 14
[    0.443285] platform tegradc.1: domain=ffffffc0f94d2d98 allocates as[0]=ffffffc0f94482b0
[    0.443670] iommu: Adding device 54340000.vic to group 15
[    0.443880] iommu: Adding device 544c0000.nvenc to group 16
[    0.444080] iommu: Adding device 54500000.tsec to group 17
[    0.444276] iommu: Adding device 54100000.tsecb to group 18
[    0.444483] iommu: Adding device 54480000.nvdec to group 19
[    0.444675] iommu: Adding device 54380000.nvjpg to group 20
[    0.445770] iommu: Adding device 546c0000.i2c to group 21
[    0.446108] iommu: Adding device 57000000.gpu to group 22
[    0.446187] platform 57000000.gpu: domain=ffffffc0f951ed98 allocates as[0]=ffffffc0f9448318
[    0.446231] platform 57000000.gpu: domain=ffffffc0f951ed98 allocates as[1]=ffffffc0f9448380
[    0.446269] platform 57000000.gpu: domain=ffffffc0f951ed98 allocates as[2]=ffffffc0f94483e8
[    0.446307] platform 57000000.gpu: domain=ffffffc0f951ed98 allocates as[3]=ffffffc0f9448450
[    0.447159] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.447177] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.447193] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.447203] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.447212] tegra-pmc: ### PMC reset status reg: 0x3
[    0.497189] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.497204] tegra-pmc: Clear bootloader IO dpd settings
[    0.497230] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.497296] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.497588] iommu: Adding device 70012000.se to group 23
[    0.498145] iommu: Adding device 1003000.pcie to group 24
[    0.498206] platform 1003000.pcie: domain=ffffffc0f9529558 allocates as[0]=ffffffc0f94484b8
[    0.498632] iommu: Adding device 7000c000.i2c to group 25
[    0.498913] iommu: Adding device 7000c400.i2c to group 26
[    0.499176] iommu: Adding device 7000c500.i2c to group 27
[    0.499436] iommu: Adding device 7000c700.i2c to group 28
[    0.499690] iommu: Adding device 7000d000.i2c to group 29
[    0.499976] iommu: Adding device 7000d100.i2c to group 30
[    0.500255] iommu: Adding device sdhci-tegra.3 to group 31
[    0.500319] platform sdhci-tegra.3: domain=ffffffc0f95ca0d8 allocates as[0]=ffffffc0f9448520
[    0.501202] iommu: Adding device 700d0000.xudc to group 32
[    0.504383] vdd-ac-bat: 5000 mV
[    0.504756] vdd-5v0-sys: 5000 mV
[    0.505461] vdd-5v0-hdmi: 5000 mV
[    0.505942] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.506199] vdd-1v8-sys: 1800 mV
[    0.506584] vdd-fan: 5000 mV
[    0.506790] vdd-fan: supplied by vdd-5v0-sys
[    0.507014] vdd-usb-vbus: 5000 mV
[    0.507262] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.507621] vdd-usb-vbus2: 5000 mV
[    0.538021] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.540212] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.541397] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.541438] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.541463] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.541828] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.550044] eventlib_kernel: keventlib is initialized, test id: 0
[    0.550414] SCSI subsystem initialized
[    0.550891] usbcore: registered new interface driver usbfs
[    0.550947] usbcore: registered new interface driver hub
[    0.550992] usbcore: registered new device driver usb
[    0.554939] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.561191] vdd-core: 1000 <--> 1162 mV at 1075 mV
[    0.562190] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.562292] random: fast init done
[    0.564344] vdd-ddr-1v1: 1150 mV
[    0.568235] vdd-pre-reg-1v35: 1350 mV
[    0.572236] vdd-1v8: 1800 mV
[    0.576235] avdd-sys-1v2: 1200 mV
[    0.580234] vdd-pex-1v0: 1050 mV
[    0.580877] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.581410] max77620-ldo3: at 3100 mV
[    0.584234] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.584770] max77620-ldo5: at 3100 mV
[    0.588243] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.592232] avdd-1v05-pll: 1050 mV
[    0.596232] avdd-io-hdmi-dp: 1050 mV
[    0.598735] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.599056] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.599356] max77620 4-003c: max77620 probe successful
[    0.602124] media: Linux media interface: v0.10
[    0.602186] Linux video capture interface: v2.00
[    0.603150] pps_core: LinuxPPS API ver. 1 registered
[    0.603166] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.603194] PTP clock support registered
[    0.606440] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.607282] Advanced Linux Sound Architecture Driver Initialized.
[    0.607949] Bluetooth: Core ver 2.22
[    0.608002] NET: Registered protocol family 31
[    0.608011] Bluetooth: HCI device and connection manager initialized
[    0.608029] Bluetooth: HCI socket layer initialized
[    0.608041] Bluetooth: L2CAP socket layer initialized
[    0.608067] Bluetooth: SCO socket layer initialized
[    0.609714] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.609740] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.609784] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.609802] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.612933] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.614279] vdd-3v3-sys: 3300 mV
[    0.614645] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.614699] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.616310] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.616734] vdd-3v3-sd: 3300 mV
[    0.617142] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.617693] avdd-io-edp-1v05: 1050 mV
[    0.618033] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.618168] vdd-usb-hub-en: 5000 mV
[    0.618493] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.619640] camchar: rtcpu character device driver loaded
[    0.620407] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.621427] clocksource: Switched to clocksource arch_sys_counter
[    0.662165] VFS: Disk quotas dquot_6.6.0
[    0.662309] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.662781] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.663237] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.663260]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.663453] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.663464] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.663482] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.663511] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.663521] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.663548] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.663561] nvmap_page_pool_init: Total RAM pages: 1012635
[    0.663571] nvmap_page_pool_init: nvmap page pool size: 126579 pages (494 MB)
[    0.663661] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.664134] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.665026] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[    0.673088] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.673556] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.673940] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.674220] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.674409] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.674693] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.674703] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.675134] NET: Registered protocol family 2
[    0.675262] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.677674] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.677895] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.678400] TCP: Hash tables configured (established 32768 bind 32768)
[    0.678558] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.678643] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.679037] NET: Registered protocol family 1
[    0.679727] RPC: Registered named UNIX socket transport module.
[    0.679742] RPC: Registered udp transport module.
[    0.679751] RPC: Registered tcp transport module.
[    0.679761] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.689770] host1x 50000000.host1x: initialized
[    0.691177] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.694445] audit: initializing netlink subsys (disabled)
[    0.694521] audit: type=2000 audit(0.543:1): initialized
[    0.695199] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.705102] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.706624] ntfs: driver 2.1.32 [Flags: R/W].
[    0.707413] 9p: Installing v9fs 9p2000 file system support
[    0.710761] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.710892] io scheduler noop registered
[    0.711186] io scheduler cfq registered (default)
[    0.713934] gic 702f9000.agic: GIC IRQ controller registered
[    0.716916] iommu: Adding device 702ef000.adsp to group 33
[    0.726276] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    0.726470] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.727114] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x6a07c0f
[    0.727129] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.728721] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.728834] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.728935] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.729137] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.729234] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.729331] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.729471] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.729584] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.729669] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.729773] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.735906] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.737669] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.739597] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.740888] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    0.741226] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    0.742467] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.742689] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.742907] Adding domain tsec-pd to PM domain host1x-pd
[    0.744979] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    0.745896] tsec 54500000.tsec: initialized
[    0.747502] tsec 54100000.tsecb: initialized
[    0.748241] Adding domain nvdec-pd to PM domain host1x-pd
[    0.751658] nvdec 54480000.nvdec: initialized
[    0.752709] Adding domain vic03-pd to PM domain host1x-pd
[    0.752902] Adding domain msenc-pd to PM domain host1x-pd
[    0.753072] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.757203] falcon 54340000.vic: initialized
[    0.758519] falcon 544c0000.nvenc: initialized
[    0.759855] falcon 54380000.nvjpg: initialized
[    0.764397] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=96
[    0.764449] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    0.764489] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    0.764507] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    0.764599] Node path /chosen/display-board not found
[    0.764610] display board info: id 0x0, fab 0x0
[    0.764668] generic_infoframe_type: 0x87
[    0.764784] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    0.764796] tegra_cec 70015000.tegra_cec: probed
[    0.764804] tegradc tegradc.0: DT parsed successfully
[    0.764854] tegradc tegradc.0: Display dc.ffffff800abc0000 registered with id=0
[    0.772550] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    0.774073] tegradc tegradc.0: probed
[    0.774839] Console: switching to colour frame buffer device 80x30
[    0.774885] tegradc tegradc.0: fb registered
[    0.776306] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    0.776401] tegradc tegradc.1: No lt-data, using default setting
[    0.776439] tegradc tegradc.1: No hpd-gpio in DT
[    0.776496] tegradc tegradc.1: DT parsed successfully
[    0.776545] tegradc tegradc.1: Display dc.ffffff800ad40000 registered with id=1
[    0.778393] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    0.779230] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    0.779244] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    0.779597] kfuse 7000fc00.kfuse: initialized
[    0.780416] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    0.781180] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.782131] tegradc tegradc.1: dpd enable lookup fail:-19
[    0.782430] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    0.782448] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    0.782852] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    0.784087] vdd-gpu: applied init 1000000uV constraint
[    0.784102] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    0.784464] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.287966] Host read timeout at address 545c00c4
[    1.289480] tegradc tegradc.1: probed
[    1.289834] tegradc tegradc.1: fb registered
[    1.293042] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.293056] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.293069] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.293085] tegradc tegradc.1: blank - powerdown
[    1.293112] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[    1.293121] Extcon DP: HPD disabled
[    1.293129] hpd: hpd_switch 0
[    1.293138] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.293150] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.293160] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.294229] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    1.294250] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.294261] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    1.294272] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    1.294284] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.294720] iommu: Adding device 0000:00:01.0 to group 35
[    1.295167] iommu: Adding device 0000:00:02.0 to group 36
[    1.296025] iommu: Adding device 0000:01:00.0 to group 37
[    1.296172] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.296276] No Device Node present for smmu client: serial8250 !!
[    1.296292] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.296323] iommu: Adding device serial8250 to group 38
[    1.298746] console [ttyS0] disabled
[    1.298818] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.310301] iommu: Adding device 0000:02:00.0 to group 39
[    1.329601] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    1.329607] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[    1.329612] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    1.329623] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[    1.329652] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.329660] pci 0000:00:01.0:   bridge window [mem 0x13000000-0x130fffff]
[    1.329671] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[    1.329693] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[    1.329714] pci 0000:02:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    1.329723] pci 0000:00:02.0: PCI bridge to [bus 02]
[    1.329727] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    1.329733] pci 0000:00:02.0:   bridge window [mem 0x13100000-0x131fffff]
[    1.330219] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    1.330224] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    1.330596] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    1.330601] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    1.781461] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    1.781466] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    3.933158] console [ttyS0] enabled
[    3.937938] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    3.947133] serial-tegra 70006200.serial: RX in PIO mode
[    3.952549] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    3.962449] [drm] Initialized
[    3.975356] brd: module loaded
[    3.983754] loop: module loaded
[    3.987080] tegra_profiler: version: 1.145, samples/io: 49/28
[    3.992974] tegra_profiler: auth: init
[    3.998149] THERMAL EST: found 2 subdevs
[    4.002146] THERMAL EST num_resources: 0
[    4.006097] [THERMAL EST subdev 0]
[    4.009512] [THERMAL EST subdev 1]
[    4.013359] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    4.022328] THERMAL EST: thz register success.
[    4.026934] THERMAL EST: end of probe, return err: 0
[    4.033097] sd: No Scsi addr parsed to reserve index
[    4.038122] hisi_sas: driver version v1.6
[    4.049395] tun: Universal TUN/TAP device driver, 1.6
[    4.054495] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.061804] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.067701] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.073700] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.080665] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.086298] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.094131] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.100101] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    4.107754] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    4.114506] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[    4.120383] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    4.140758] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    4.153134] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): bad mac address at /chosen/nvidia,ethernet-mac: missing.
[    4.164433] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Assigning random ethernet address 72:e5:fa:30:c9:ff
[    4.175879] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    4.187329] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
[    4.187329]  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[    4.187329]  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    4.218687] PPP generic driver version 2.4.2
[    4.223182] PPP BSD Compression module registered
[    4.227908] PPP Deflate Compression module registered
[    4.233008] PPP MPPE Compression module registered
[    4.237809] NET: Registered protocol family 24
[    4.242350] usbcore: registered new interface driver r8152
[    4.247892] usbcore: registered new interface driver asix
[    4.253354] usbcore: registered new interface driver ax88179_178a
[    4.259494] usbcore: registered new interface driver cdc_ether
[    4.265372] usbcore: registered new interface driver net1080
[    4.271081] usbcore: registered new interface driver cdc_subset
[    4.277039] usbcore: registered new interface driver zaurus
[    4.282670] usbcore: registered new interface driver cdc_ncm
[    4.288517] VFIO - User Level meta-driver version: 0.3
[    4.294928] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.301488] ehci-pci: EHCI PCI platform driver
[    4.305994] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.312183] ohci-pci: OHCI PCI platform driver
[    4.316671] ohci-platform: OHCI generic platform driver
[    4.324545] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    4.330933] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    4.339317] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9681c00 id
[    4.345713] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[    4.354757] usbcore: registered new interface driver uas
[    4.354820] usbcore: registered new interface driver usb-storage
[    4.354944] usbcore: registered new interface driver usbserial
[    4.358121] tegra-xudc-new 700d0000.xudc: device count: 1
[    4.359745] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    4.359755] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    4.359769] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    4.359793] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    4.359817] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    4.360478] mousedev: PS/2 mouse device common for all mice
[    4.360554] usbcore: registered new interface driver xpad
[    4.418730] tegra-xusb 70090000.xusb: Falling back to user helper
[    4.490698] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    4.500474] rtc rtc1: alarm rtc device
[    4.504259] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    4.511423] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    4.518166] i2c /dev entries driver
[    4.523806] i2c i2c-6: Added multiplexed i2c bus 7
[    4.529040] i2c i2c-6: Added multiplexed i2c bus 8
[    4.533853] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[    4.541765] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    4.572788] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    4.601996] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    4.608606] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.616195] imx219 8-0010: board setup failed
[    4.620632] imx219: probe of 8-0010 failed with error -121
[    4.627387] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    4.636642] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    4.643715] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    4.651122] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.660461] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    4.669429] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    4.678437] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.687756] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    4.696715] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    4.705733] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.715042] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    4.724002] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    4.732006] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    4.739836] tegra_aotag tegra-aotag: Registering sensor 0
[    4.745333] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    4.750577] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    4.757086] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.766418] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    4.774641] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    4.783423] parse_throttle_dt_data: Num cap clks = 6
[    4.788396] parse_throttle_dt_data: clk=cclk_g type=2
[    4.793463] parse_throttle_dt_data: clk=gpu type=4
[    4.798276] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    4.804390] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    4.810501] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    4.816510] parse_throttle_dt_data: clk=emc type=3
[    4.821703] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.831118] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.840570] tegra_throttle_probe: probe successful. #cdevs=4
[    4.846972] FAN dev name: pwm-fan
[    4.850383] FAN:gpio request success.
[    4.854118] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    4.860086] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    4.866865] pwm_fan_driver pwm-fan: fan tach request irq success
[    4.872889] pwm_fan_driver pwm-fan: tach period: 1000
[    4.878032] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    4.885604] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    4.893344] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    4.901173] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    4.909000] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    4.916829] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    4.924655] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    4.932486] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    4.940315] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    4.948230] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    4.957510] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[    4.965560] device-mapper: uevent: version 1.0.3
[    4.970621] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    4.983239] tegra210-cpufreq cpufreq: probe()...completed
[    4.989821] sdhci: Secure Digital Host Controller Interface driver
[    4.996012] sdhci: Copyright(c) Pierre Ossman
[    5.000370] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.006657] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    5.021170] tegra-se 70012000.se: tegra_se_probe: complete
[    5.027418] hidraw: raw HID events driver (C) Jiri Kosina
[    5.034749] usbcore: registered new interface driver usbhid
[    5.040355] usbhid: USB HID core driver
[    5.046389] ashmem: initialized
[    5.051124] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    5.058267] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    5.069500] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    5.070309] nvpmodel: initialized successfully
[    5.072293] usbcore: registered new interface driver snd-usb-audio
[    5.072421] No Device Node present for smmu client: snd-soc-dummy !!
[    5.072429] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    5.072461] iommu: Adding device snd-soc-dummy to group 40
[    5.102180] OPE platform probe
[    5.102322] OPE platform probe successful
[    5.102619] OPE platform probe
[    5.102740] OPE platform probe successful
[    5.127974] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    5.129373] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    5.129600] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    5.129774] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    5.129954] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    5.130145] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    5.130314] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    5.130513] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    5.130689] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    5.130950] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    5.131136] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    5.150214] u32 classifier
[    5.150218]     Actions configured
[    5.150337] Initializing XFRM netlink socket
[    5.151241] NET: Registered protocol family 10
[    5.152330] NET: Registered protocol family 17
[    5.152350] NET: Registered protocol family 15
[    5.152439] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    5.152505] Bluetooth: RFCOMM socket layer initialized
[    5.152531] Bluetooth: RFCOMM ver 1.11
[    5.152538] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.152545] Bluetooth: HIDP socket layer initialized
[    5.152568] 9pnet: Installing 9P2000 support
[    5.152647] Key type dns_resolver registered
[    5.153271] Registered cp15_barrier emulation handler
[    5.153293] Registered setend emulation handler
[    5.154792] registered taskstats version 1
[    5.156036] Adding domain ve2-pd to PM domain host1x-pd
[    5.156320] Adding domain ve-pd to PM domain host1x-pd
[    5.160200] isp 54600000.isp: initialized
[    5.161294] isp 54680000.isp: initialized
[    5.180874] last reset is due to software reset
[    5.180880] KERNEL: PMC reset status reg: 0x3
[    5.184962] clk_cbus_recalc_rate: no gbus parent
[    5.184972] clk_cbus_round_rate: no gbus parent
[    5.184974] clk_cbus_round_rate: no gbus parent
[    5.184994] clk_cbus_recalc_rate: no gbus parent
[    5.185231] clk_cbus_recalc_rate: no gbus parent
[    5.185234] clk_cbus_round_rate: no gbus parent
[    5.185236] clk_cbus_round_rate: no gbus parent
[    5.185241] clk_cbus_recalc_rate: no gbus parent
[    5.185255] tegra_dvfs: GPU-cap: registered
[    5.185572] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    5.185575] tegra dvfs: vdd-core: nominal 1075mV, offset 1000000uV, step 12500uV, scaling enabled
[    5.185577] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[    5.187728] tegra_dvfs: vdd-gpu-vts: registered
[    5.188712] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    5.189647] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    5.190746] input: gpio-keys as /devices/gpio-keys/input/input1
[    5.230589] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:20:59 UTC (946689659)
[    5.233100] vi 54080000.vi: vi_probe: ++
[    5.237156] vi 54080000.vi: initialized
[    5.239581] vi 54080000.vi: subdev nvcsi--2 bound
[    5.239620] vi 54080000.vi: subdev imx219 7-0010 bound
[    5.240722] vi 54080000.vi: subdev nvcsi--1 bound
[    5.242212] Disable partitions left on by BL
[    5.242217]   disb
[    5.242303] bwmgr: missing cdev-type property
[    5.242486] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    5.242497] DRAM derating cdev registered.
[    5.252206] eth0: 0xffffff800a3fc000, 72:e5:fa:30:c9:ff, IRQ 405
[    5.301840] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    9.397550] r8168: eth0: link up
[    9.405565] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    9.429543] IP-Config: Guessing netmask 255.255.255.0
[    9.434603] IP-Config: Complete:
[    9.437834]      device=eth0, hwaddr=72:e5:fa:30:c9:ff, ipaddr=192.168.9.9, mask=255.255.255.0, gw=255.255.255.255
[    9.448175]      host=192.168.9.9, domain=, nis-domain=(none)
[    9.453916]      bootserver=255.255.255.255, rootserver=192.168.9.119, rootpath=
[    9.462007] ALSA device list:
[    9.464971]   #0: tegra-hda at 0x70038000 irq 82
[    9.469593]   #1: tegra-snd-t210ref-mobile-rt565x
[   40.053770] vdd-fan: disabling
[   40.056832] vdd-usb-vbus: disabling
[   40.060333] vdd-usb-vbus2: disabling
[   40.063944] vddio-sdmmc-ap: disabling
[   40.067816] vddio-sdmmc3-ap: disabling
[   40.071747] vdd-3v3-sd: disabling
[   40.075074] avdd-io-edp-1v05: disabling
[   40.078909] vdd-usb-hub-en: disabling
[   55.541542] random: crng init done
[   64.629696] tegra-xusb 70090000.xusb: cannot find firmware....retry after 1 second
[   65.653598] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[   65.663253] tegra-xusb 70090000.xusb: Falling back to user helper
[  107.645339] VFS: Unable to mount root fs via NFS, trying floppy.
[  107.651805] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
[  107.659032] Please append a correct "root=" boot option; here are the available partitions:
[  107.667386] 0100            8192 ram0 [  107.670960]  (driver?)
[  107.673319] 0101            8192 ram1 [  107.676893]  (driver?)
[  107.679265] 0102            8192 ram2 [  107.682840]  (driver?)
[  107.685199] 0103            8192 ram3 [  107.688772]  (driver?)
[  107.691140] 0104            8192 ram4 [  107.694713]  (driver?)
[  107.697071] 0105            8192 ram5 [  107.700644]  (driver?)
[  107.703009] 0106            8192 ram6 [  107.706579]  (driver?)
[  107.708937] 0107            8192 ram7 [  107.712508]  (driver?)
[  107.714872] 0108            8192 ram8 [  107.718442]  (driver?)
[  107.720800] 0109            8192 ram9 [  107.724372]  (driver?)
[  107.726736] 010a            8192 ram10 [  107.730395]  (driver?)
[  107.732753] 010b            8192 ram11 [  107.736410]  (driver?)
[  107.738774] 010c            8192 ram12 [  107.742431]  (driver?)
[  107.744790] 010d            8192 ram13 [  107.748448]  (driver?)
[  107.750810] 010e            8192 ram14 [  107.754467]  (driver?)
[  107.756825] 010f            8192 ram15 [  107.760481]  (driver?)
[  107.762855] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[  107.771106] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.299-tegra #6
[  107.777620] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[  107.783612] Call trace:
[  107.786069] [<ffffff800808ba30>] dump_backtrace+0x0/0x198
[  107.791458] [<ffffff800808bff4>] show_stack+0x24/0x30
[  107.796506] [<ffffff8008f77350>] dump_stack+0xa0/0xc4
[  107.801548] [<ffffff8008f743f4>] panic+0x128/0x2a4
[  107.806336] [<ffffff80096211a0>] mount_block_root+0x19c/0x2a0
[  107.812069] [<ffffff80096214dc>] mount_root+0x11c/0x134
[  107.817281] [<ffffff8009621664>] prepare_namespace+0x170/0x1b8
[  107.823100] [<ffffff8009620dc8>] kernel_init_freeable+0x230/0x254
[  107.829184] [<ffffff8008f7a348>] kernel_init+0x18/0x108
[  107.834398] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[  107.839701] SMP: stopping secondary CPUs
[  107.843737] Kernel Offset: disabled
[  107.847216] Memory Limit: none
[  107.855729] Rebooting in 5 seconds..
之后就反复重启
你有照著我們的developer guide做過嗎?
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3273/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#wwpID0E01H0HA
理論上你在flash的時候指定好要用NFS boot,刷好之後參數就不用自己改了才對。
也有可能是你的host上的nfs的權限沒有設好之類的。
host这边的nfs自测了是可以用的,板子进入kernel后也自测过了,也是好的,甚至通过板子上kernel下面是可以通过nfs挂载rootfs的,但是就是u-boot阶段挂载不可以,默认编译的时候我看过菜单配置是有nfs在boot的时候是开启的,启动参数我添加了v3,但是还是挂载不了,很是奇怪
所以如果你的板子直接開機進系統,是可以用NFS來mount的(在host上local測試也可以?)、但是如果開機的時候就透過NFS mount rootfs就會失敗?
可以問一下你是用哪一版的L4T嗎?是我們的DevKit還是自己的底板?
我在DevKit上用32.7.3試過了是可以用NFS在開機時正常mount rootfs的,你要不要整個步驟重來、照著我們的developer guide再做一次?
這是你自己重新編譯kernel的意思?為什麼需要這樣做?
我也是32.7.3,我自己编译的kernel,就是用自己编译的是走一遍然后心里有数,我忘记备份u-boot对kernel启动参数的保存了,现在我不管有没有sd卡都进入u-boot都进入不了kernel了我只有一个nano的设备,没有其他的设备
Tegra210 (P3450-0000) # pri
arch=arm
baudrate=115200
board=p3450-0000
board_name=p3450-0000
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_dcache_off=dcache off
boot_efi_binary=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr ${fdtcontroladdr};fi;load ${devtype} ${devnumfi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_pci_enum=pci enum
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc1 mmc0 usb0 nvme0 pxe dhcp
bootargs=root=/dev/nfs rw nfsroot=192.168.9.119:/nfs/rootfs,v3 console=ttyS0,115200 init=/linuxrc ip=192.168.9.9
bootcmd=pci enum ; pci ; ext4load mmc 1:1 0x84000000 /boot/Image ; ext4load mmc 1:1 83100000 /boot/tegra210-p3448-0002-p3449-0000-b00.dtb ; boot
bootcmd_dhcp=run boot_net_usb_start; run boot_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfotp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00011:UNDI:003000;setenv bootp_arch 0xb;if dhcp ${kernel_addr_r}; theile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_mmc1=devnum=1; run mmc_boot
bootcmd_nvme0=devnum=0; run nvme_boot
bootcmd_pxe=run boot_net_usb_start; run boot_pci_enum; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=devnum=0; run usb_boot
bootdelay=2
cbootargs=tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_d=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xf00 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net
cpu=armv8
distro_bootcmd=setenv nvme_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fdt_addr=83100000
fdt_addr_r=0x83000000
fdt_copy_node_paths=/chosen/plugin-manager:/chosen/reset:/chosen/display-board:/chosen/proc-board:/chosen/pmu-board:/external-memory-controller@
fdt_copy_prop_paths=/bpmp/carveout-start:/bpmp/carveout-size:/chosen/eks_info:/chosen/nvidia,bluetooth-mac:/chosen/nvidia,ethernet-mac:/chosen/nux,initrd-start:/chosen/linux,initrd-end:/serial-number:/psci/nvidia,system-lp0-disable
fdt_copy_src_addr=83100000
fdt_high=ffffffffffffffff
fdtcontroladdr=fc5fa380
fdtoverlay_addr_r=0x90200000
initrd_high=ffffffffffffffff
ipaddr=192.168.9.9
kernel_addr_r=0x84000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x84000000
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
nvme_boot=run boot_pci_enum; run boot_dcache_off; run nvme_init; if nvme dev ${devnum}; then devtype=nvme; run scan_dev_for_boot_part; fi
nvme_init=if ${nvme_need_init}; then setenv nvme_need_init false; nvme scan; fi
preboot=if test -e mmc 1:1 /u-boot-preboot.scr; then load mmc 1:1 ${scriptaddr} /u-boot-preboot.scr; source ${scriptaddr}; fi
pxefile_addr_r=0x90100000
ramdisk_addr_r=0x83200000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scor_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devm}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefi; fi;done;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootaa64.efi; then echo Found EFI removable media binary efi/boot/bootaa64D FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinu FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-t_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x90000000
serverip=192.168.9.119
soc=tegra210
stderr=serial
stdin=serial
stdout=serial
usb_boot=run boot_pci_enum; usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=nvidia
现在我三张sd卡全进入不了了,启动参数没备份呜呜
可以给我一个你刚刚可以nfs挂载的启动参数吗?我参考你环境自己恢复一下,你只需要在u-boot阶段pri然后信息复制一下
重點是,你如果只是要用NFS mount rootfs的話,我確定照著我們的developer guide是可以成功的,不用搞這些自己重新編譯kernel、自己設定bootarg之類有的沒的。
搞不太懂為什麼你好像經常自己走一些我們在文件上沒有提到的彎路…
因为我参考很多文章然后一个个找共性才配置的呜呜,很多板子他配置了bootargs我才这样做的,所以我是想把这个打通
請你就先照著developer guide做一遍看能不能成功就好…
如果照著我們的文件會失敗才有討論價值
你這樣找一堆教學東拼西湊的,我們根本不知道你到底是哪一步做錯
