Hi. Using a custom carrier with Orin NX + SSD, flashed with a image built with Yocto (Jetson Linux release: R35.5.0 JetPack release: 5.1.3)
I’m able to find 2 UARTs: /dev/ttyTCU0 (debug) and /dev/ttyTHS0 (UART A), however, I’m not able to find UART B.
I’m testing by doing a chant between RX with TX and doing picocom at that port and see if I receive my input back.
This makes me confused because, when I boot, this is my dmesg output:
root@p3768-0000-p3767-0000:~# dmesg | grep tty
[ 0.000000] Kernel command line: mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb ipv6.disable=1 audit=0 ipv6.disable=1 audit=0
[ 0.275490] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.882535] printk: console [ttyTCU0] enabled
[ 3.756296] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[ 3.771035] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[ 3.785787] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 7.382253] systemd[1]: Created slice Slice /system/getty.
[ 7.383918] systemd[1]: Created slice Slice /system/serial-getty.
[ 8.187436] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 8.222714] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB1
[ 8.472178] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB2
[ 8.491034] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB3
So it looks like I have 3 UARTS, but they are different from what I can test?
I think the UART I’m not able to get is the one related to M.2 KEY E. Do I have to enable something extra? (even tho I find it weird it appears 3 uarts available on the dmesg.)
Also, I get different addresses from what Ive seen in other posts in this forum:
UART0 => UART2(PX04, PX05, PX06, PX07): uartb@3110000 (serial1) - Unused => To M.2 Key E
UART1 => UART1(PR02, PR03, PR04, PR05): uarta@3100000 (serial0) - /dev/ttyTHS0 => General UART
UART2 => UART3(PCC05, PCC06): uartc@c280000 (serial2) - /dev/ttyTCU0 => Debug
I dont have any c280000 or 3110000.
Could someone help?
