I’m working with the Radar over the ttyTHS1 and ttyTHS2 UART ports provided by the Tegra-High Speed Uart drivers.
I got some basic information on UARTs here :
THS0, THS1, THS4 and TCU0
I’m using THS1 and newly enabled THS2 UART for Radar.
from this I faced the exact error even though the approach is different as described here
Firstly, i’ve disabled the combined-uart provided as :
common/tegra194-p3668-common.dtsi
@@ -247,8 +247,8 @@
combined-uart {
console-port;
combined-uart;
status = "disabled";
here’s discussion thread, NX change console to other uart, you may refer to.
please also refer to Topic 153941, check mappings for serial ports of ttyTHS*, and UART*
thanks
Thanks for pointing to right solution, i missed out on disabling combined-uart at tegra194-mb1-bct-misc-l4t.cfg.
The system turns of gracefully if there is no data being written while trying to reboot the board.
I also found that if I echo 0 > /dev/ttyTHS2 it clears the buffer and solves the issue. But I found that the THSUart driver has support for reset as :
tegra194-soc-uart.dtsi : serial@c280000 { … resets = <&bpmp_resets TEGRA194_RESET_UARTC>; reset-names = “serial”; … }
But in the driver : serial-tegra.c : static struct tegra_uart_chip_data tegra186_uart_chip_data = { .tx_fifo_full_status = true, .allow_txfifo_reset_fifo_mode = false, … }
Is there a chance of providing Reset on this UART to provide a state change ?
As i referred the driver supporting it : serial-tegra.c (line 1188) reset_control_assert(tup->rst); udelay(10); reset_control_deassert(tup->rst);
it’s uart driver to lookup and obtain an exclusive reference to a reset controller.
please check if there’s handler for controlling, then you might have implementation to call API for uart reset.
for example,
1811 static int tegra_uart_probe(struct platform_device *pdev)
1812 {
1863 tup->rst = devm_reset_control_get(&pdev->dev, "serial");
1864 if (IS_ERR(tup->rst)) {
1865 dev_err(&pdev->dev, "Couldn't get the reset\n");
1866 return PTR_ERR(tup->rst);
I am trying to debug in L4T sources as i want to now is there any more changes required for flash.sh script to work gracefully :
Changes already done :
Disabled TCU0 on common/tegra194-p3668-common.dtsi
