I am happy to use either gdm3 or lightdm, but neither are stable on my Ubuntu 18.04 system, they will work for either one or several boots after I take corrective action, but inevitably this results in the greeter not loading - the last few times (at least) I noticed this was immediately after I did a sudo apt update. The graphics card on my Intel Core i5 system is an Nvidia GTX 970, and I manually installed nvidia-driver-415 using apt when I could not load a greeter as soon as I had installed.
Searching here and elsewhere, I have tried many things to resolve this, which I will outline below. If you know something else I can try - to get either greeter stable - please let me know.
gdm3
gdm3:
Installed: 3.28.3-0ubuntu18.04.3
Even with WaylandEnable=false uncommented in /etc/gdm3/custom.conf, I could never login, instead of the greeter I would see either a black screen or graphic distortion like a black screen with some pink lines across the top, and I am only able to login setting nomodeset.
gdm3 sample distortion:
https://i.imgur.com/iTB2YFW.jpg
With gd3 not working, I tried lightdm, and on encountering similar issues switched back to gdm3 again:
sudo apt-get install gdm3
sudo dpkg-reconfigure gdm3
This seemed to work - kind of, for the first few days I could boot most of the time. I have quiet splash permanently removed from my boot options, and boot was sometimes hanging on Started NVIDIA Persistence Daemon as below:
gdm fail 1
https://i.stack.imgur.com/l1Qv4.jpg
Another time with gdm3 I saw the following output instead of the greeter:
gdm fail 2:
https://i.stack.imgur.com/HFgsm.jpg
gdm fail 3:
https://i.stack.imgur.com/V7j78.jpg
lightdm
lightdm:
Installed: 1.26.0-0ubuntu1
When I use lightdm instead, and the greeter does not load, I see a flashing black screen with a single white underscore top left. I can never get to a TTY using ctrl + alt + f3/f4/f5, REISUB does not work, so I hard rebooted, the greeter loads with nomodeset, and from there without logging in I switch to a TTY and I have tried what I outline below. Sometimes if I just reboot again without nomodeset the greeter will just load properly, without my changing anything.
flashing black screen with single white cursor top let:
All pictures of my monitor are now also attached to this post
https://i.imgur.com/WKaFarS.jpg
nvidia-bug-report.log.gz, generated after one first nomodeset login after lightdm fail now attached
Observing these permissions:
-rw------- 1 dusf dusf 56 Jan 7 17:38 .Xauthority
-rw------- 1 dusf dusf 15886 Jan 7 17:38 .ICEauthority
drwxrwxrwt 16 root root 4096 Jan 7 17:45 /tmp
I input the following, and could login normally next reboot:
sudo chown dusf:dusf .Xauthority
sudo chown dusf:dusf .ICEauthority
sudo chmod a+wt /tmp
The next time the issue occurred I input the following, and could login next reboot:
sudo dpkg-reconfigure lightdm
In .xsession-errors, I noticed the following line, which I thought could be relevant considering I see an underscore instead of a greeter?
_=/usr/bin/dbus-update-activation-environment
Next temporary fix:
sudo mv .Xauthority .Xauthority.bak
Again:
sudo apt-get purge lightdmsudo apt-get install --reinstall lightdm
sudo apt-get install gnome
After a sudo apt upgrade a few days ago with the same issue recurring I input all of the following and everything seemed fine for a few days:
sudo apt upgradesudo apt purge lightdm
sudo apt purge gnome
sudo apt purge nvidia*
sudo apt remove nvidia-driver-415
reboot
sudo apt purge nvidia-*
sudo apt install nvidia-415
sudo apt install nvidia-driver-415
reboot
sudo apt purge xorg-* xserver-xorg
sudo apt install xorg xserver-xorg
sudo dpkg-reconfigure xorg
sudo apt purge ubuntu-gnome-desktop
sudo apt purge gnome-desktop-environment
apt install ubuntu-gnome-desktop
sudo apt install ubuntu-gnome-desktop
sudo apt install --reinstall lightdm
The next time the issue occurred I noticed in my .bash_history the last commands I input were:
sudo apt update
sudo apt upgrade
and I uploaded the following logs:
I read adding an xrandr line to some files may be the next step, but the actual lines seem to be system specific, and their are recommendations on adding them to different files.
How can I begin to resolve the issue, either with gdm3 or lightdm please?
nvidia-bug-report.log.gz (1.05 MB)
