Hello everyone, I’m ready to give now but here are the details:
AMD Ryzen CPU X1600, X370 chipset (no embedded video card)
secure boot off
monitor connected through display port
Ubuntu 16.04 with 4.13.0-43 kernel (all updated/upgraded)
390.25 driver installed through PPA (396 even worse)
nouveau disabled through modprobe.d file (as recommended) plus
CUDA not involved - did not even try
kernel startup flags
/boot/vmlinuz-4.13.0-43-generic.efi.signed root=UUID=XXX ro quiet splash nouveau.modeset=0 grub_gfxmode=vesa rdblacklist=nouveau vt.handoff=7
tried wo grub_gfxmode=vesa as well
dmesg | grep nvidia
[ 1.102143] nvidia: loading out-of-tree module taints kernel.
[ 1.102148] nvidia: module license 'NVIDIA' taints kernel.
[ 1.108726] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 1.146669] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[ 1.146946] nvidia 0000:1d:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 1.169085] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 390.59 Wed May 9 21:59:27 PDT 2018
[ 1.169638] [drm] [nvidia-drm] [GPU ID 0x00001d00] Loading driver
[ 1.169640] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:1d:00.0 on minor 0
[ 2.556906] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 240
[ 4.474767] nvidia-modeset: Allocated GPU:0 (GPU-80c6c27c-272c-f670-4a6b-0ddef4992cb5) @ PCI:0000:1d:00.0
[ 4.971648] nvidia-modeset: Freed GPU:0 (GPU-80c6c27c-272c-f670-4a6b-0ddef4992cb5) @ PCI:0000:1d:00.0
[ 14.638972] nvidia-modeset: Allocated GPU:0 (GPU-80c6c27c-272c-f670-4a6b-0ddef4992cb5) @ PCI:0000:1d:00.0
xorg.conf generated with nvidia-xconfig or no file at all
Problem
No login screen, The system is running in low-graphics mode error, which won’t let you through (even with fallback mode). No errors in Xorg.log, but this for every video port. Can switch to terminal though.
config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
Obvious question - what is wrong with my system? And how to fix. I’ve spent quite a while going through various howto and forum threads - to no luck.
Alex
nvidia-smi
| NVIDIA-SMI 390.59 Driver Version: 390.59 |
| 0 GeForce GTX 106... Off | 00000000:1D:00.0 On | N/A |
| 0% 28C P8 7W / 200W | 16MiB / 6075MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1464 G /usr/lib/xorg/Xorg 14MiB |
No errors in kernl.log
Xorg.0.log (21.3 KB)
lightdm.log (151 KB)
