acrawfor19, your cpu is too new for the running kernel so the intel gpu is not supported. You can enable alpha support for it using kernel parameter
i915.alpha_support=1
but that’s likely unstable. Better upgrade to kernel 5.3.
Upgraded kernel to 5.3.1-050301-generic and the Intel gpu is supported now. Thanks! I just tried installing Ubuntu’s latest drivers and the Nvidia driver refuses to load now (Tried 418,430,435,and 440). Any suggestions would be greatly appreciated.
andrew@andrew-HP:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Please make sure the needed kernel headers are also installed
sudo apt install --reinstall linux-headers-5.3.1-050301-generic
then check if the nvidia module is installed/post the output of
dkms status
Results of ‘sudo apt install --reinstall linux-headers-5.3.1-050301-generic’
andrew@andrew-HP:~/kernel5_3$ sudo apt install --reinstall linux-headers-5.3.1-050301-generic
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package linux-headers-5.3.1-050301-generic is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'linux-headers-5.3.1-050301-generic' has no installation candidate
I used the following to install the headers again:
andrew@andrew-HP:~/kernel5_3$ sudo dpkg -i linux-headers-5.3.1-050301_5.3.1-050301.201909210632_all.deb
(Reading database ... 220343 files and directories currently installed.)
Preparing to unpack linux-headers-5.3.1-050301_5.3.1-050301.201909210632_all.deb ...
Unpacking linux-headers-5.3.1-050301 (5.3.1-050301.201909210632) over (5.3.1-050301.201909210632) ...
Setting up linux-headers-5.3.1-050301 (5.3.1-050301.201909210632) ...
Now I rebooted…
Output of ‘dkms status’:
andrew@andrew-HP:~/kernel5_3$ dkms status
nvidia, 430.26: added
Now I tried ‘nvidia-smi’ again:
andrew@andrew-HP:~/kernel5_3$ nvidia-smi
You also need the -generic headers,
linux-headers-5.3.1-050301-generic_5.3.1-050301.201909210632_amd64.deb
Install those, run
sudo dkms install nvidia/430.26 --all
and post the output of
dkms status
afterwards
I’m sorry - I missed the header error in the kernel build:
andrew@andrew-HP:~/kernel5_3$ sudo dpkg -i *.deb
Preparing to unpack linux-image-unsigned-5.3.1-050301-generic_5.3.1-050301.201909210632_amd64.deb ...
/etc/kernel/preinst.d/intel-microcode:
libkmod: ERROR ../libkmod/libkmod-config.c:656 kmod_config_parse: /etc/modprobe.d/iwlwifi.conf line 8: ignoring bad line starting with ''options'
Unpacking linux-image-unsigned-5.3.1-050301-generic (5.3.1-050301.201909210632) over (5.3.1-050301.201909210632) ...
Preparing to unpack linux-modules-5.3.1-050301-generic_5.3.1-050301.201909210632_amd64.deb ...
Unpacking linux-modules-5.3.1-050301-generic (5.3.1-050301.201909210632) over (5.3.1-050301.201909210632) ...
Setting up linux-modules-5.3.1-050301-generic (5.3.1-050301.201909210632) ...
Setting up linux-image-unsigned-5.3.1-050301-generic (5.3.1-050301.201909210632) ...
Processing triggers for linux-image-unsigned-5.3.1-050301-generic (5.3.1-050301.201909210632) ...
/etc/kernel/postinst.d/dkms:
* dkms: running auto installation service for kernel 5.3.1-050301-generic
Error! Your kernel headers for kernel 5.3.1-050301-generic cannot be found.
Please install the linux-headers-5.3.1-050301-generic package,
or use the --kernelsourcedir option to tell DKMS where it's located
...done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.3.1-050301-generic
Alas, nothing has changed in how it works and in the glxinfo and nvidia-smi outputs.
However, the output of
xrandr --listproviders
has changed - previously it listed two providers (both named modesetting), now there’s only one. Not sure if it’s relevant at all.
Attached a new report after doing what you asked.
Everything is in place but the gpu-manager doesn’t seem to run. Please run
sudo dpkg-reconfigure ubuntu-drivers-common
sudo systemctl enable gpu-manager
and reboot. Afterwards, attach /var/log/gpu-manager.log
Aaand I immediately remembered why I have masked it in the first place, and disabled it via the kernel parameter for good measure.
After booting up for the first time, all worked well except that the initial problem was not solved. I looked at /var/log/gpu-manager.log (attached) and noticed that a new Xorg conf file has been created. Just in case I rebooted again - and got a black screen. AFAIK my NVIDIA GPU is not connected to the DP. But I couldn’t make the eDP (the laptop’s own display) work either - xrandr kept telling me about bad parameters or something like that. Also, the names of the outputs changed from something like DP-1 to something like DP-1-1, so all my display management scripts got broken.
In any case, here’s the contents of that new file 11-nvidia-prime.conf that was created by gpu-manager:
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Section "OutputClass"
Identifier "Nvidia Prime"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
Option "IgnoreDisplayDevices" "CRT"
Option "PrimaryGPU" "Yes"
ModulePath "/x86_64-linux-gnu/nvidia/xorg"
EndSection
A couple of things: I had to prepend “/usr/lib” to the ModulePath since that’s the correct path (“/x86_64-linux-gnu” does not exist at all) and I had to comment out the line setting up PrimaryGPU to make the external screen work. I also renamed 10-nvidia.conf to just 10-nvidia (I think it disables it) since it’s pretty similar to the new file:
As you can probably guess, the initial problem still persists.
Just in case - getting the NVIDIA GPU working while being able to use the DisplayPort would be great. But ideally, I want to be able to use the NVIDIA GPU only when I need it, and rely on the Intel GPU for most of the time. NVIDIA GPU would then say disabled during that time since the MSI BIOS makes it impossible to control its fans, and they keep spinning up and down creating a lot of unnecessary noise.
I had this exact setup working with nouveau before these experiments with the proprietary driver - the only thing I had to do to make a program use the NVIDIA GPU was to add DRI_PRIME=1 to its environment variables. The issue with nouveau though is that the performance is just terrible - barely above of the Intel GPU. gpu-manager.log (1.68 KB)
Attached, the one where the fixes to the 11-nvidia-prime.conf are applied so I can use the external display.
Let me know if you also need the one with the pristine 11-nvidia-prime.conf, as generated by the gpu-manager.
All nvidia config files are gone in that log. Please create and attach an nvidia-bug-report.log with both 11-nvidia-prime.conf and 10-nvidia.conf in place. Both files are required.
I just checked and /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf is definitely there, along with other conf files.
In any case, I renamed 10-nvidia back to 10-nvidia.conf and restarted Xorg. The new report is attached. nvidia-bug-report.log.gz (338 KB)
