I have been using Ubuntu with Quadro M1000M and it was never a smooth experience to be able to sync my two external monitors + notebook monitor. Before I was on Ubuntu 18 with 390 and it was somewhat ok, I had to unplug and plug the third monitor from 15 to 30 times every restart and eventually it would endup working and I could leave the computer on for around 20 days until the nvidia screws again and somehow fails to accept the third monitor and restart was required.
One day I updated the driver and it was the worst thing I could have ever done to myself, after many days of fighting with the drivers and configs I managed to rollback to 390 but it was super laggy and often the OS will start with black screen.
A restart was required, another 1h fighting with the OS and I could usually recover the old setup.
One day, everything broke. None of my previous tricks worked. So I decided to install Ubuntu 18 from scratch. Next I tried to install the lastest driver (after all, when things break you go for the latest and check if finally things are fixed), to my disappointment, Ubuntu 18 is not able to install 440, the only version that worked was 435.
With 435 it is impossible to configure the 3rd monitor, no matter what I tried. And I tried for about a week, all sorts of shit you can imagine I tried. Waste of time.
So I decided to upgrade to Ubuntu 19. I removed all nvidia drivers and upgraded. Then installed 440 and it worked (facepalm).
Now I have Ubuntu 19 with KDE and 440, the third monitor works but only for 24h (facepalm 2x). Every day, around 12:50 to 12:59 (WTF) the graphics card reset, the monitors are then mixed and the config with 3 monitors goes to trash. Its impossible to recover and it only works again if restarting. Oh, but not if you try to save the xorg config. If you do that, the computer will start with black screen. So you need to boot safely and get rid of older xorg config, otherwise it wont work.
Conclusions:
I noticed that after restarting nvidia with sudo rmmod nvidia_uvm ; sudo modprobe nvidia_uvm
and doing a offload sudo /usr/share/sddm/scripts/Xsetup
if [ -e /sbin/prime-offload ]; then
echo running NVIDIA Prime setup /sbin/prime-offload
/sbin/prime-offload
fi
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
and then restarting plasma: killall plasmashell && plasmashell > /dev/null 2>&1 & disown
, if I am lucky I may be able to recover the previous state, but in a few hours it will happen again and the monitor composition goes to trash.
This is the output for my nvidia-smi:
Mon Mar 23 15:50:30 2020
| NVIDIA-SMI 440.64 Driver Version: 440.64 CUDA Version: 10.2 |
| 0 Quadro M1000M Off | 00000000:01:00.0 On | N/A |
| N/A 42C P5 N/A / N/A | 1146MiB / 2002MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1315 G /usr/lib/xorg/Xorg 700MiB |
| 0 1911 G /usr/bin/kwin_x11 52MiB |
| 0 1918 G /usr/bin/krunner 0MiB |
| 0 1947 G nvidia-settings 16MiB |
| 0 1986 G /usr/bin/systemsettings5 31MiB |
| 0 2010 G /usr/bin/ksysguard 36MiB |
| 0 4225 G .../Downloads/GoLand-2019.3.3/jbr/bin/java 141MiB |
| 0 10794 G plasmashell 101MiB |
| 0 17648 G /usr/bin/ksysguard 52MiB |
This is uname-a:
Linux user 5.3.0-42-generic #34-Ubuntu SMP Fri Feb 28 05:49:40 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
I see that the crash is usually related to a certain GPU action or a process that is trying to schedule to use it, or something like this.
The question here is: How can I restart the gpu without having to restart the computer ? how can I offload the processes that are using the GPU and restart the graphics card ? any ideas ?
Thank you.
