I have an Asus branded RTX 2060 with 4 Dell U2718Q’s connected. When I enable “Fractional Scaling” and select 125% or 150% on all for monitors from the “Display Settings” the scale is completely messed up. The only way to describe it is that some of the monitors scale is way beyond 150% but other are untouched. The actual desktop of each monitor seems to overlap as well.
Thanks,
Scott
nvidia-bug-report.log (2.2 MB)
Fractional scaling on Xorg is an experimental Ubuntu feature that doesn’t seem to be working correctly. Rather try setting this manually:
https://ricostacruz.com/til/fractional-scaling-on-xorg-linux
Thank you for the response. I gave the instructions on that site a try, but the results were similar to what I experienced with the built in fractional settings of Ubuntu 20.
I found some references to this bug: https://bugs.launchpad.net/ubuntu/+source/mutter/+bug/1873403
I think I’ll wait it out and see if anything comes from that.
Thanks again.
Scott
