hi generix, I’m here again…
last time ,very thanks for your help to solve my problem that ubuntu 20.04 with mosaic on settings, it works well!
recently,i found that ubuntu update to 22.04 LTS,so i upgrade my os. As expected, there are fatal problems…
my computer is Graphic workstation,with 2 Quadro RTX4000,os=ubuntu 22.04 LTS. This time I used only 1 Graphics card ,4 ports to 4 4k monitor.My RTX driver version no. is 510.73.05.
A part of my xorg.conf is
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “Quadro RTX 4000”
BusID “PCI:1:0:0”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “Stereo” “0”
Option “nvidiaXineramaInfo” “FALSE”
Option “nvidiaXineramaInfoOrder” “DFP-6”
Option “metamodes” “GPU-b16ec084-0226-c21e-496a-193149a3140f.DP-2: nvidia-auto-select +11520+0, GPU-b16ec084-0226-c21e-496a-193149a3140f.DP-0: nvidia-auto-select +7680+0, GPU-b16ec084-0226-c21e-496a-193149a3140f.DP-4: nvidia-auto-select +0+0, GPU-b16ec084-0226-c21e-496a-193149a3140f.USB-C-0: nvidia-auto-select +3840+0”
Option “MultiGPU” “Off”
Option “SLI” “off”
Option “BaseMosaic” “on”
Option “AllowEmptyInitialConfiguration”
Option “Coolbits” “4”
SubSection “Display”
Depth 24
EndSubSection
EndSection
Also,I do the same setting which in 20.04 works that : make nvidia-drm modeset=0
hengda@hengda-MS-7850:/etc/X11$ grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
/etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
/etc/modprobe.d/nvidia-graphics-drivers-kms.conf:# This file was generated by nvidia-drivers-510
/etc/modprobe.d/nvidia-graphics-drivers-kms.conf:options nvidia-drm modeset=0
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=0
Then i Execute “sudo update-initramfs -u”
When the workstation is restarted, it cannot start successfully and cannot enter the system desktop. Some words of failure will flash on the screen:
usbhid 3-9:1.0:can’t add hid device :-71
/dev/sda2: clean, 225315/14622720 files, 4440669/58476288 blocks
ucsi_ccg 0-0008: UCSI_GET_PDOS failed (-70)
ucsi_ccg 0-0008:possible USCI driver bug 4
At this time, although I cannot access the graphical desktop, I can connect to the workstation through SSH.This shows that the system can run, but can not enter the graphical desktop.
If i change the setting in xorg.conf ,mosaic on to off,everything is back to normal.
So I came to ask for help again please…
