the current UE4 Connector wont appear in the available plugin list. when i change to 100.3.69 its back.
Thank you.
Matthias
Thank you.
Matthias
Matthias,
I attempted to reproduce this and I could not. Due to the UAC prompt of the Unreal Engine Connector install, sometimes things get mixed up between the state of the installed plugins and what the Launcher indicates.
My recommendation is for you to “UNINSTALL” the 100.4.94
version. This will remove the installer package from your hard disk. Then you can “UPDATE” it, which will redownload the installer package and rerun the install process, which I would expect should give you the latest version that you want.
