I have 2 monitors connected into P50’s docking station (one VGA, one DVI). My desired layout is: notebook monitor (DP-4) on the left, right of it first monitor(DP-3.2) (rotated 90degrees), right of it second monitor (DP-3.3). Every monitor has 1920x1080 resolution.
But somehow I’m stuck with different layout (from left: rotated DP-3.2, DP-3.3, DP-4).
When I run nvidia-settings and change layout there and confirm, the monitors flicker for a while (it looks like it is trying the layout I want), but after few seconds I’m back at the wrong layout.
This is snippet of output of /var/log/Xorg.0.log when I confirm the new layout:
[ 562.601] (II) NVIDIA(0): Setting mode "DPY-6:nvidia-auto-select+0+0,DPY-0:nvidia-auto-select+1920+0{rotation=right
[ 564.179] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-3.3: nvidia-auto-select @1920x1080 +3000+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1
[ 565.665] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-3.3: nvidia-auto-select @1920x1080 +1080+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1
[ 567.043] (II) NVIDIA(0): Setting mode "DP-4: nvidia-auto-select @1920x1080 +3000+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-3.3: nvidia-auto-select @1920x1080 +1080+0 {ViewPortIn=1920x1080, ViewPortOut=192
I really don’t grok what is the DPY-6, when my monitors are DP-4, DP-3.2 and DP-3.3.
I tried to delete /etc/X11/xorg.conf and generate new, deleting ~/.nvidia-settings-rc and ~/.nv.
I’m on Fedora 26. I’ve tried nvidia drivers installed from rpmfusion and from https://negativo17.org/nvidia-driver/
In this google drive are two tarballs generated by nvidia-bug-report.sh: https://drive.google.com/drive/folders/0B9OUl4QZrhPFak95UC1jQ0tJVEE?usp=sharing
