I tried to make a camera driver, but it doesn’t work.
I am getting logs like the attached.
[ 180.284816] nv_imx563: module verification failed: signature and/or required key missing - tainting kernel
[ 180.296195] imx563 9-001a: probing v4l2 sensor at addr 0x1a
[ 180.296986] imx563 9-001a: mclk name not present, assume sensor driven externally
[ 180.296989] imx563 9-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 180.297105] imx563 9-001a: tegracam sensor driver:imx563_v2.0.6
[ 180.297108] imx563 9-001a: imx563_power_on: power on
[ 180.306662] imx563 9-001a: imx563_board_setup: error during i2c read probe (-121)
[ 180.314380] imx563 9-001a: imx563_power_off: power off
[ 180.314400] imx563 9-001a: board setup failed
[ 180.318958] imx563: probe of 9-001a failed with error -121
[ 180.324685] imx563 10-001a: probing v4l2 sensor at addr 0x1a
[ 180.325114] imx563 10-001a: mclk name not present, assume sensor driven externally
[ 180.325118] imx563 10-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 180.325166] imx563 10-001a: tegracam sensor driver:imx563_v2.0.6
[ 180.325168] imx563 10-001a: imx563_power_on: power on
[ 180.334548] imx563 10-001a: imx563_power_off: power off
[ 180.334635] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx563 10-001a bound
[ 180.335570] imx563 10-001a: detected imx563 sensor
[ 180.439945] imx563 10-001a: imx563_open:
[ 399.977871] imx563 10-001a: imx563_power_on: power on
[ 399.999157] bwmgr API not supported
[ 400.008446] imx563 10-001a: imx563_set_mode:
[ 400.031383] imx563 10-001a: imx563_start_streaming:
[ 402.657371] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 402.666518] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 402.676483] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 402.684204] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 402.694861] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 402.702585] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 402.713615] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 405.472634] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 405.481787] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 405.492509] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 405.500223] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 405.510861] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 405.518574] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 405.529403] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 405.538931] imx563 10-001a: imx563_stop_streaming:
[ 405.542769] bwmgr API not supported
[ 405.552504] imx563 10-001a: imx563_power_off: power off
[ 499.332345] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 499.960255] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 510.311302] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx563 10-001a unbind
[ 510.311380] imx563 10-001a: free reset_gpio
[ 516.058311] imx563 9-001a: probing v4l2 sensor at addr 0x1a
[ 516.059026] imx563 9-001a: mclk name not present, assume sensor driven externally
[ 516.059030] imx563 9-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 516.059039] imx563 9-001a: imx563_power_get: unable to request reset_gpio (-16)
[ 516.066667] imx563 9-001a: unable to power get
[ 516.071260] imx563 9-001a: tegra camera driver registration failed
[ 516.077758] imx563: probe of 9-001a failed with error -14
[ 516.083444] imx563 10-001a: probing v4l2 sensor at addr 0x1a
[ 516.083830] imx563 10-001a: mclk name not present, assume sensor driven externally
[ 516.083833] imx563 10-001a: avdd, iovdd and/or dvdd reglrs. not present, assume sensor powered independently
[ 516.083945] imx563 10-001a: tegracam sensor driver:imx563_v2.0.6
[ 516.083949] imx563 10-001a: imx563_power_on: power on
[ 516.092485] imx563 10-001a: imx563_power_off: power off
[ 516.092577] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx563 10-001a bound
[ 516.093319] imx563 10-001a: detected imx563 sensor
[ 516.102067] imx563 10-001a: imx563_open:
[ 516.114091] imx563 10-001a: imx563_open:
[ 521.362332] imx563 10-001a: imx563_power_on: power on
[ 521.385972] bwmgr API not supported
[ 521.396966] imx563 10-001a: imx563_set_mode:
[ 521.420311] imx563 10-001a: imx563_start_streaming:
[ 523.999999] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 524.009150] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 524.019489] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 524.027209] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 524.037884] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 524.045607] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 524.056415] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 526.815983] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 526.825135] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 526.835479] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 526.843201] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 526.853864] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 526.861580] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 526.872422] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 529.488963] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 529.498108] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 529.508696] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 529.516406] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 529.527081] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 529.534804] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 529.545659] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 529.555197] imx563 10-001a: imx563_stop_streaming:
[ 529.559059] bwmgr API not supported
[ 529.567509] imx563 10-001a: imx563_power_off: power off
[ 6105.346437] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 6105.972526] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 6580.206124] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 6580.829243] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 6637.560430] imx563 10-001a: imx563_power_on: power on
[ 6637.574725] bwmgr API not supported
[ 6637.584271] imx563 10-001a: imx563_set_mode:
[ 6637.606663] imx563 10-001a: imx563_start_streaming:
[ 6640.209370] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 6640.218546] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 6640.228567] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 6640.236331] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 6640.247022] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 6640.254831] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 6640.265709] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 6643.024910] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 6643.034072] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 6643.044502] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 6643.052274] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 6643.063151] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 6643.070963] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 6643.082028] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 6643.091652] imx563 10-001a: imx563_stop_streaming:
[ 6643.096236] bwmgr API not supported
[ 6643.106355] imx563 10-001a: imx563_power_off: power off
[ 6783.299594] imx563 10-001a: imx563_open:
kworker/2:9-143 [002] … 6637.589044: rtcpu_vinotify_event: tstamp:208370643329 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6667845235328 data:0x399e300010000000
kworker/2:9-143 [002] … 6637.589047: rtcpu_vinotify_event: tstamp:208370643591 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6667845245056 data:0x0000000031000001
kworker/2:9-143 [002] … 6637.589048: rtcpu_vinotify_event: tstamp:208370643879 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6667845343616 data:0x399e2d0010000000
kworker/2:9-143 [002] … 6637.589048: rtcpu_vinotify_event: tstamp:208370644128 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6667845353472 data:0x0000000031000002
kworker/2:9-143 [002] … 6640.280973: rtcpu_vinotify_event: tstamp:208454736450 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6670540426304 data:0x399e300010000000
kworker/2:9-143 [002] … 6640.280977: rtcpu_vinotify_event: tstamp:208454736711 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6670540483904 data:0x0000000031000001
kworker/2:9-143 [002] … 6640.280977: rtcpu_vinotify_event: tstamp:208454737000 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6670540501504 data:0x399e2d0010000000
kworker/2:9-143 [002] … 6640.280978: rtcpu_vinotify_event: tstamp:208454737245 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:6670540561920 data:0x0000000031000002
kworker/2:9-143 [002] … 6648.832761: rtcpu_string: tstamp:208720601142 id:0x04010000 str:“VM0 deactivating.”
I’ve done a lot of research and verification, but I’m stuck.
Any help would be appreciated.
dmesg.txt (81.1 KB)
log.txt (2.0 KB)
