So I tried this
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "ServerFlags"
Option "AutoAddDevices" "false"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "ConnectedMonitor" "DFP-0"
Option "CustomEDID" "DFP-0:/etc/X11/1920x1080.bin"
BusID "PCI:134:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
DefaultDepth 24
Option "Stereo" "0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
Option "ModeDebug" "true"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Using the 1920x1080.bin I got from edid-generator, also tried my U2713HM.edid.
[ 781.044] (II) NVIDIA(0): NVIDIA GPU GRID M40 (GM107GL-A) at PCI:134:0:0 (GPU-0)
[ 781.044] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 781.044] (--) NVIDIA(0): VideoBIOS: 82.07.6d.00.0b
[ 781.044] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 781.045] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 781.045] (--) NVIDIA(GPU-0): CRT-0 Name Aliases:
[ 781.045] (--) NVIDIA(GPU-0): DPY-0
[ 781.045] (--) NVIDIA(GPU-0): VGA-0
[ 781.045] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 781.045] (--) NVIDIA(GPU-0): LNX Linux FHD (DFP-0): connected
[ 781.045] (--) NVIDIA(GPU-0): LNX Linux FHD (DFP-0): Internal TMDS
[ 781.045] (--) NVIDIA(GPU-0): LNX Linux FHD (DFP-0) Name Aliases:
[ 781.045] (--) NVIDIA(GPU-0): DFP
[ 781.045] (--) NVIDIA(GPU-0): DFP-0
[ 781.045] (--) NVIDIA(GPU-0): DPY-1
[ 781.045] (--) NVIDIA(GPU-0): DVI-I-0
[ 781.045] (--) NVIDIA(GPU-0): DPY-EDID-64866c46-1f56-ed22-cce3-db6d0656cceb
[ 781.045] (--) NVIDIA(GPU-0): LNX Linux FHD (DFP-0): 165.0 MHz maximum pixel clock
[ 781.045] (--) NVIDIA(GPU-0): --- EDID for LNX Linux FHD (DVI-I-0) ---
[ 781.045] (--) NVIDIA(GPU-0): EDID Version : 1.3
[ 781.045] (--) NVIDIA(GPU-0): Manufacturer : LNX
[ 781.045] (--) NVIDIA(GPU-0): Monitor Name : LNX Linux FHD
[ 781.045] (--) NVIDIA(GPU-0): Product ID : 0x0000
[ 781.045] (--) NVIDIA(GPU-0): 32-bit Serial Number : 0x00000000
[ 781.045] (--) NVIDIA(GPU-0): Serial Number String : Linux #0
[ 781.045] (--) NVIDIA(GPU-0): Manufacture Date : 2012, week 5
[ 781.045] (--) NVIDIA(GPU-0): DPMS Capabilities : Standby Suspend Active Off
[ 781.045] (--) NVIDIA(GPU-0): Input Type : Analog
[ 781.045] (--) NVIDIA(GPU-0): Prefer first detailed timing : Yes
[ 781.046] (--) NVIDIA(GPU-0): Supports GTF : No
[ 781.046] (--) NVIDIA(GPU-0): Maximum Image Size : 500 mm x 280 mm
[ 781.046] (--) NVIDIA(GPU-0): Valid HSync Range : 66.0 kHz - 68.0 kHz
[ 781.046] (--) NVIDIA(GPU-0): Valid VRefresh Range : 59.0 Hz - 61.0 Hz
[ 781.046] (--) NVIDIA(GPU-0): EDID maximum pixel clock : 150.0 MHz
[ 781.046] (--) NVIDIA(GPU-0): Standard Timings:
[ 781.046] (--) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 781.046] (--) NVIDIA(GPU-0): Detailed Timings:
[ 781.046] (--) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 781.046] (--) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 781.046] (--) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 781.046] (--) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 781.046] (--) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 781.046] (--) NVIDIA(GPU-0): H/V Polarity : +/+
[ 781.046] (--) NVIDIA(GPU-0): Image Size : 500 mm x 281 mm
[ 781.046] (--) NVIDIA(GPU-0): RGB 444 bpcs : 8
[ 781.046] (--) NVIDIA(GPU-0): --- End of EDID for LNX Linux FHD (DVI-I-0) ---
[ 781.046] (--) NVIDIA(GPU-0): Raw EDID bytes:
[ 781.046] (--) NVIDIA(GPU-0): 00 ff ff ff ff ff ff 00 31 d8 00 00 00 00 00 00
[ 781.046] (--) NVIDIA(GPU-0): 05 16 01 03 6d 32 1c 78 ea 5e c0 a4 59 4a 98 25
[ 781.046] (--) NVIDIA(GPU-0): 20 50 54 00 00 00 d1 c0 01 01 01 01 01 01 01 01
[ 781.046] (--) NVIDIA(GPU-0): 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
[ 781.046] (--) NVIDIA(GPU-0): 45 00 f4 19 11 00 00 1e 00 00 00 ff 00 4c 69 6e
[ 781.046] (--) NVIDIA(GPU-0): 75 78 20 23 30 0a 20 20 20 20 00 00 00 fd 00 3b
[ 781.046] (--) NVIDIA(GPU-0): 3d 42 44 0f 00 0a 20 20 20 20 20 20 00 00 00 fc
[ 781.046] (--) NVIDIA(GPU-0): 00 4c 69 6e 75 78 20 46 48 44 0a 20 20 20 00 05
[ 781.046] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 781.046] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 781.046] (--) NVIDIA(GPU-0): DFP-1 Name Aliases:
[ 781.046] (--) NVIDIA(GPU-0): DPY-2
[ 781.046] (--) NVIDIA(GPU-0): DVI-I-1
[ 781.046] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 781.046] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 781.046] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 781.046] (--) NVIDIA(GPU-0): DFP-2 Name Aliases:
[ 781.046] (--) NVIDIA(GPU-0): DPY-3
[ 781.046] (--) NVIDIA(GPU-0): DVI-I-2
[ 781.046] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 781.046] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 781.046] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 781.046] (--) NVIDIA(GPU-0): DFP-3 Name Aliases:
[ 781.046] (--) NVIDIA(GPU-0): DPY-4
[ 781.046] (--) NVIDIA(GPU-0): DVI-I-3
[ 781.046] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 781.046] (II) NVIDIA(GPU-0):
[ 781.046] (II) NVIDIA(GPU-0): --- Building ModePool for LNX Linux FHD (DFP-0) ---
[ 781.046] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60":
[ 781.046] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 781.046] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 781.046] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 781.046] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 781.046] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 781.046] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 781.046] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 781.046] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 781.046] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 781.046] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 781.046] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 781.046] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 781.046] (II) NVIDIA(GPU-0): Base Depth 32
[ 781.046] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 781.046] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 781.046] (II) NVIDIA(GPU-0): Mode "1920x1080_60" is valid.
[ 781.047] (II) NVIDIA(GPU-0): Validating Mode "1920x1080_60":
[ 781.047] (II) NVIDIA(GPU-0): Mode Source: EDID
[ 781.047] (II) NVIDIA(GPU-0): 1920 x 1080 @ 60 Hz
[ 781.047] (II) NVIDIA(GPU-0): Pixel Clock : 148.50 MHz
[ 781.047] (II) NVIDIA(GPU-0): HRes, HSyncStart : 1920, 2008
[ 781.047] (II) NVIDIA(GPU-0): HSyncEnd, HTotal : 2052, 2200
[ 781.047] (II) NVIDIA(GPU-0): VRes, VSyncStart : 1080, 1084
[ 781.047] (II) NVIDIA(GPU-0): VSyncEnd, VTotal : 1089, 1125
[ 781.047] (II) NVIDIA(GPU-0): Sync Polarity : +H +V
[ 781.047] (II) NVIDIA(GPU-0): Viewport 1920x1080+0+0
[ 781.047] (II) NVIDIA(GPU-0): Horizontal Taps 1
[ 781.047] (II) NVIDIA(GPU-0): Vertical Taps 1
[ 781.047] (II) NVIDIA(GPU-0): Base SuperSample x1
[ 781.047] (II) NVIDIA(GPU-0): Base Depth 32
[ 781.047] (II) NVIDIA(GPU-0): Distributed Rendering 1
[ 781.047] (II) NVIDIA(GPU-0): Overlay Depth 32
[ 781.047] (II) NVIDIA(GPU-0): Mode "1920x1080_60" is valid.
Same exact deadlock. Whole system is alive but zombied. Nothing works, cant kill Xorg, Xorg at 100% 1 cpu core.
[77451.852814] nvidia-modeset: WARNING: GPU:2: Lost display notification (0:0x00000000); continuing.
[77484.768514] NVRM: GPU at PCI:0000:86:00: GPU-4bfabc64-9458-38dd-b6a0-287523e9fa01
[77484.768558] NVRM: GPU Board Serial Number: 0121415042015
[77484.768565] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000000
[77492.769009] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000001
[77500.769532] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000002
[77508.770067] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000003
[77516.770573] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000004
[77524.771095] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000005
[77532.771618] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000006
[77540.772128] NVRM: Xid (PCI:0000:86:00): 16, Head 00000000 Count 00000007
