Under http://127.0.0.1:11000/settings > System tab you can uncheck the Analytics and data usage and it remains unchecked - as long as you don’t refresh the page.
@aniculescu I’ve installed the latest update, but I still see this ticking itself each time I reload the page. Can you confirm which version it’s fixed in, and how I check my version is up-to-date?
@aniculescu I can also confirm, after rebooting and checking for updates that I:
Have not received a new update via the DGX dashboard since my initial setup about a month ago.
Still am not seeing the true state of the telemetry via the DGX Dashboard, it appears to be permanently enabled.
EDIT: I was able to get an update to appear in the dashboard by first running sudo apt update and then refreshing the web page, but am still experiencing the same behavior as @DannyTup.
Got it, thanks! Are you able to confirm what the current version is? The release notes online say 7.3.0 was released on Oct 30th, but after updating cat /etc/dgx-release still shows 7.2.3 for me.
