I keep hitting the same error, when using the web interface for DGX Dashboard on http://localhost:11000/ it keeps on saying ”Update Available” in blue block, you click Update Now, it downloads, reboots and same message, over and over. I did do the whole manual process but it did not solve the problem.
@WayneV Please try:
sudo apt update
sudo apt dist-upgrade
sudo fwupdmgr refresh
sudo fwupdmgr upgrade
sudo reboot
From the command line.
If the error persists after reboot, run:
sudo nvidia-bug-report.sh
Like I said, I did the whole manual process, so it’s upgraded, but still seeing the message. Will do a bug report.
I had the same issue fwiw.
