Update - Dashboard
“Update” keeps popping up on the DGX Dashboard.
I’ve ran it several times today and after a restart, and waiting maybe 10 minutes, it pops again.
I know this will be addressed but when? What is the ETA on the update that will address this (I’m assuming we will see release notes prior to updating as well?).
Stating “we will be addressing with next update” isn’t going to cut it.
Please provide greater transparency on the timeline for this as this is a feature/fix that should have been addressed day 1.
Hi @jaim12005, can you check if you are running into the expired key issue (documented here: DGX Spark apt update failure (EXPKEYSIG)) by running sudo apt update in a terminal?
This wasn’t the issue.
Looks like we need release notes implemented asap. As I was thinking it was the same update, not realising their are in fact instances where multiple updates get pushed within any given day.
We really need a timeline on the next major release.
