Unable to flash NVME AGX Orin 64GB Dev Kit with USB on ubuntu 22.04
previous issues already discussed about this topic
Enviorment
Ubuntu native 22.04 (same one 20.04)
JetPack 6.2
error log was steps just start flash using sdkmanager
14:41:54.118 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS - error is: rpcbind: another rpcbind is already running. Aborting
14:41:54.410 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: clnt_create: RPC: Authentication error
14:41:54.410 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS - error is: clnt_create: RPC: Authentication error
14:41:54.410 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: NFS server is not running
I found another solution.
it shoud do on machine that launch sdkmanager
file
/etc/hosts.allow
add below lines
rpcbind: 127.0.0.1
portmap: ALL
lockd: ALL
mountd: ALL
statd: ALL
rquotad: ALL
with this below error printed but installation will be started without error on sdkmanager
14:47:55 ERROR: Flash Jetson Linux - flash: clnt_create: RPC: Authentication error
Some questions to confirm:
  • Is your ubuntu a native or a virtual machien?
  • What is your target JP version?
  • Please click EXPORT LOGS button to export zip file using sdk manager.
sdkmanager ran on native ubuntu 22.04. also 20.04 has same problem.
Tried to install JetPack 6.2
i cloudn’t attach log files from my company infrastrucure.
let me know which information you want to get. i cloud add text on comment.
Please try Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
And follow Quick Start — NVIDIA Jetson Linux Developer Guide to flash your machine.
