Unable to format internal eMMC storage
Hi
I’m unable to flash internal eMMC storage of Jetson AGX orin 64gb development kit,
I tried installing jetpack6 multiple time in eMMC via sdk manager but it got failed,
Then i tried installing it in external SSD, then it got succeed,
After booting up i tried flashing eMMC via disk utils, it’s showing me below error,
4439d62769ab8924eda2f5809ecf380f395d602d_2_690x453
Before this i had installed Jetpack6 in eMMC several times, but now i cannot, but when i try in external m2 SSD it got installed
Here the output of the commands
(base) jetson@ubuntu:~/visionsentinal$ lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0          7:0    0     4K  1 loop /snap/bare/5
loop1          7:1    0 164.3M  1 loop /snap/chromium/2906
loop2          7:2    0  69.2M  1 loop /snap/core22/1614
loop3          7:3    0  69.2M  1 loop /snap/core22/1624
loop4          7:4    0  61.2M  1 loop /snap/core24/493
loop5          7:5    0  65.9M  1 loop /snap/cups/1059
loop6          7:6    0 402.2M  1 loop /snap/gnome-46-2404/49
loop7          7:7    0  91.7M  1 loop /snap/gtk-common-themes/1535
loop8          7:8    0  87.3M  1 loop /snap/mesa-2404/142
loop9          7:9    0  33.7M  1 loop /snap/snapd/21761
loop10         7:10   0    16M  1 loop
mmcblk0      179:0    0  59.2G  0 disk
mmcblk0boot0 179:32   0     4M  1 disk
mmcblk0boot1 179:64   0     4M  1 disk
zram0        252:0    0   2.6G  0 disk [SWAP]
zram1        252:1    0   2.6G  0 disk [SWAP]
zram2        252:2    0   2.6G  0 disk [SWAP]
zram3        252:3    0   2.6G  0 disk [SWAP]
zram4        252:4    0   2.6G  0 disk [SWAP]
zram5        252:5    0   2.6G  0 disk [SWAP]
zram6        252:6    0   2.6G  0 disk [SWAP]
zram7        252:7    0   2.6G  0 disk [SWAP]
zram8        252:8    0   2.6G  0 disk [SWAP]
zram9        252:9    0   2.6G  0 disk [SWAP]
zram10       252:10   0   2.6G  0 disk [SWAP]
zram11       252:11   0   2.6G  0 disk [SWAP]
nvme0n1      259:0    0 238.5G  0 disk
├─nvme0n1p1  259:1    0   237G  0 part /
├─nvme0n1p2  259:2    0   128M  0 part
├─nvme0n1p3  259:3    0   768K  0 part
├─nvme0n1p4  259:4    0  31.6M  0 part
├─nvme0n1p5  259:5    0   128M  0 part
├─nvme0n1p6  259:6    0   768K  0 part
├─nvme0n1p7  259:7    0  31.6M  0 part
├─nvme0n1p8  259:8    0    80M  0 part
├─nvme0n1p9  259:9    0   512K  0 part
├─nvme0n1p10 259:10   0    64M  0 part
├─nvme0n1p11 259:11   0    80M  0 part
├─nvme0n1p12 259:12   0   512K  0 part
├─nvme0n1p13 259:13   0    64M  0 part
├─nvme0n1p14 259:14   0   400M  0 part
└─nvme0n1p15 259:15   0 479.5M  0 part
(base) jetson@ubuntu:~/visionsentinal$ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/nvme0n1p1  233G   37G  184G  17% /
tmpfs            31G  170M   31G   1% /dev/shm
tmpfs            13G   35M   13G   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           6.2G  148K  6.2G   1% /run/user/1000
Share us what error you got from sdkmanager.
I haven’t saved the logs, to retrieve the logs again I’ve to flash which I can’t do
The only way to make it work is using sdkmanager to flash. Thus we need your log.
I mean we need the flash failure log to understand what is going on.
