I have a L40s and need to configure it to work in gpumode.
I ran .\displaymodeselector.exe --gpumode physical_display_enabled_8GB_bar1
and then .\nvidia-smi.exe -fdm 0
The nvidia control panel now shows the displayports but when I connect a computer screen to the display port it does not show it as connected and no image output on the display.
Is there any steps that I need to take ? PS. I’ve tested the cables and connectors with a RTX4060 and it works fine.
Hi…
can you provide the output of “nvidia-smi.exe -q” here, and then also try the displaymodeselector tool option “physical_display_enabled_256MB_bar1”, then again run nvidia-smi and provide the output pls…
does the devicemanager show any issues with the L40S GPU?
thanks
-Frank
