Unable to initiate jetson-inference container after update
HI, i am having problem starting the jetson-inference container after update on my nano (Jetpack 4.5.1).
Logs as follows;
nano@nano:~/jetson-inference$ docker/run.sh
reading L4T version from /etc/nv_tegra_release
L4T BSP Version: L4T R32.5.2
size of data/networks: 2414907831 bytes
CONTAINER: nvcr.io/ea-linux4tegra/jetson-inference:r32.5.2
DATA_VOLUME: --volume /home/nano/jetson-inference/data:/jetson-inference/data --volume /home/nano/jetson-inference/python/training/classification/data:/jetson-inference/python/training/classification/data --volume /home/nano/jetson-inference/python/training/classification/models:/jetson-inference/python/training/classification/models --volume /home/nano/jetson-inference/python/training/detection/ssd/data:/jetson-inference/python/training/detection/ssd/data --volume /home/nano/jetson-inference/python/training/detection/ssd/models:/jetson-inference/python/training/detection/ssd/models
USER_VOLUME:
USER_COMMAND:
V4L2_DEVICES: --device /dev/video0
localuser:root being added to access control list
Unable to find image ‘nvcr.io/ea-linux4tegra/jetson-inference:r32.5.2’ locally
docker: Error response from daemon: unauthorized: authentication required.
See ‘docker run --help’.
nano@nano:~/jetson-inference$ sudo docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
dustynv/jetson-inference r32.4.4 1bdd63ba4343 3 months ago 3.11GB
dustynv/jetson-inference r32.5.0 ccc2a5f19dad 9 months ago 2.89GB
nvcr.io/nvidia/dli/dli-nano-ai v2.0.1-r32.5.0 bc9051ff252d 11 months ago 3.73GB
It seems that after the update, the required L4T Version is R32.5.2.
Do i need to download a new container and if Yes, can you point provide me with the pull command to do this ?
Another strange this is that when i run JTOP on the terminal, the Jetpack version shown is now UNKNOWN. What is the possible reason for this to happen?
Benjamin
Hi @Benjamin_Lim, can you try running it like this?
docker/run.sh -c dustynv/jetson-inference:r32.5.0
I will also patch this in the docker/run.sh script so that it uses the right version of the container.
OK, this issue should be fixed by commit 4e1987 - thanks for letting me know.
This is probably because JTOP also requires update for L4T R32.5.2 - I will let @rbonghi know.
Hi @dusty_nv , i tried running but still there is error
nano@nano:~/jetson-inference$ docker/run.sh -c dustynv/jetson-inference:r32.5.0
[sudo] password for nano:
CONTAINER: dustynv/jetson-inference:r32.5.0
USER_VOLUME:
USER_COMMAND:
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown.
Not sure what causes this …
HI @dusty_nv, have you got any further updates on how to resolve the container issue.
Hi Benjamin!,
I work with docker and I had the same problem, the only way to resolve it was uninstall the docker (completely) and then reinstall it. I tried a lot of steps on forums but these did not work. At now, when a new uptdate is released, I preffer to update all system except the docker. I hope this could help you.
Hi @Benjamin_Lim, try updating or re-cloning your jetson-inference repo, because I had patched this issue by adding --security-opt seccomp=unconfined to this line of docker/run.sh:
https://github.com/dusty-nv/jetson-inference/blob/9b66fbf38dcd0e81f37eb3748db3df0a221b4fa7/docker/run.sh#L168
HI @dusty_nv . Thanks for your help.
I did not re-clone the repo though. Instead what i reckon was that editing the run.sh directly might also work and it did.
After that i tried to run
sudo docker/run.sh -c dustynv/jetson-inference:r32.5.0
and all is working again.
Thanks again. Cheers !
Hi @cadiaz , thanks for your advice.
I found my solution through Dusty. Please refer to my reply to Dusty a while ago.
Thanks Anyway.
