Unable to install adafruit-blinka on Jetson Nano
I have been following the tutorial in the link below:
I’m currently stuck on last part, where I need to install adafruit-blinka.
This is the command I am running:
ra@Ding:~$ sudo pip3 install Adafruit-Blinka
And this is the error I am getting:
The directory ‘/home/ra/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
The directory ‘/home/ra/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Collecting Adafruit-Blinka
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))’: /simple/adafruit-blinka/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))’: /simple/adafruit-blinka/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))’: /simple/adafruit-blinka/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))’: /simple/adafruit-blinka/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))’: /simple/adafruit-blinka/
Could not fetch URL https://pypi.python.org/simple/adafruit-blinka/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘pypi.python.org’, port=443): Max retries exceeded with url: /simple/adafruit-blinka/ (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1076)’))) - skipping
Could not find a version that satisfies the requirement Adafruit-Blinka (from versions: )
No matching distribution found for Adafruit-Blinka
Please check with the package owner to see if they support the Jetson environment.
