Trambak
#1
I am trying to install CUDA 8.0 on my windows 7 machine that has aGeForce 1050Ti card. I get the following warning at the system check stage:
The graphics driver could not find a compatible graphics hardware.
Any help on this issue would be great.
Keep the driver you already have for your 1050Ti.
Run the CUDA 8 installer but deselect the option to install the driver that is bundled with the CUDA 8 installer.
Then you should be able to safely ignore that warning, and CUDA 8 should just work with your existing driver.
