Running nvidia-settings results in output…
ERROR: Unable to load info from any available system
Same as in Nvidia-settings - ERROR: Unable to load info from any available system - #12 by timurguochen except the supposed “fix” did not work for me.
nvidia-bug-report.log.gz (992.7 KB)
System information… LMDE 4 Debbie (cinnamon 5.0.5, linux 4.19.0-17-amd64)
My laptop is an acer aspire v nitro with a GeForce GTX 960M graphics card.
In the bug report I see the following errors (in order of appearance)…
[ 8.256] (EE) Failed to load module “nv” (module does not exist, 0)
[ 8.366] (EE) NVIDIA(G0): GPU screens are disabled
[ 8.366] (EE) NVIDIA(G0): Failing initialization of X screen
[ 837.941] (EE) event16 - Touchpad: kernel bug: Touch jump detected and discarded.
See Touchpad jumping cursor bugs — libinput 1.12.6 documentation for details
After uninstalling (following NvidiaGraphicsDrivers - Debian Wiki) and reinstalling…
nvidia-bug-report.log.gz (995.6 KB)
NOTE: now only EE’s are…
[ 9.392] (EE) Failed to load module “nv” (module does not exist, 0)
[ 9.505] (EE) NVIDIA(G0): GPU screens are disabled
[ 9.505] (EE) NVIDIA(G0): Failing initialization of X screen
Output of apt show nvidia-xconfig is…
Package: nvidia-xconfig
Version: 418.56-1
Priority: optional
Section: contrib/x11
Maintainer: Debian NVIDIA Maintainers <pkg-nvidia-devel@lists.alioth.debian.org>
Installed-Size: 250 kB
Pre-Depends: nvidia-installer-cleanup
Depends: libc6 (>= 2.14)
Recommends: libgl1-nvidia-glx-any
Homepage: https://download.nvidia.com/XFree86/nvidia-xconfig/
Download-Size: 84,3 kB
APT-Sources: https://deb.debian.org/debian buster/contrib amd64 Packages
Description: deprecated X configuration tool for non-free NVIDIA drivers
This tool is deprecated. The NVIDIA drivers now automatically integrate with
the Xorg Xserver configuration. Creating an xorg.conf is no longer needed for
normal setups.
The nvidia-xconfig program helps with manipulation of X configuration
files, primarily for systems that use the non-free drivers provided by
NVIDIA. It automatically changes the configuration to use the NVIDIA
driver and can add additional options given on the command line.
