I have a jetson TX2.
I want to install the database oracle on ubuntu.
However, you need an alien to install the oracle rpm file.
sudo a-t-get update
sudo apt-get install alien
If you enter the above command, the following error message appears.
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package alien
Why? It is very positive.
It is there, you probably just need to enable the right repository:
root@x2:~# apt search alien
Sorting... Done
Full Text Search... Done
alien/xenial 8.95 all
convert and install rpm and other packages
This is my “/etc/apt/sources.list” (if you edit be sure to run “sudo apt update” before looking for packages):
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted universe multiverse
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted universe multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-backports main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-backports main restricted universe multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted universe multiverse
I do have doubts Oracle can run on this architecture. I’m very curious to find out if this works.
Thank you for answer.
But…
I have tried apt search as a guide but the following results are shown.
root@tegra-ubuntu:~# apt search alien
Sorting… Done
Full Text Search… Done
No results for alien.
The contents are as follows.
deb Index of /ubuntu-ports xenial main restricted
deb-src Index of /ubuntu-ports xenial main restricted
distribution.
deb Index of /ubuntu-ports xenial-updates main restricted
deb-src Index of /ubuntu-ports xenial-updates main restricted
Uncomment the following two lines to add software from the ‘universe’
repository.
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu-ports xenial-security main restricted
deb-src Index of /ubuntu-ports xenial-security main restricted
Be aware that if there are any changes to sources.list, then you need to run “sudo apt update” before the changes will take effect. In a similar way, you may need to run “sudo apt update” prior to seeing simple package updates. Have you run “sudo apt update” prior to the “search”?
