I am attempting to flash a Jetson Nano and when I move to step 2 in the sdk manager, it says, “Oops could not load the Nvidia SDK details.” I know for a fact that my network is perfectly fine. From looking around the forum, it appears this is a very common issue. How do I fix this?
Yes. I’m using Linux 18.04.
This problem started happening earlier. I have used the SDK manager to flash other Jetsons. I took a week trip and when I got back it gave me that error.
Is this a VM?
No
Can you please share the SDKM logs?
SDKM_logs_2023-03-14_15-12-56.zip (290.3 KB)
Looks like you are running an old version of the SDKM. Please update to 1.9.2.
That worked
Great!
Incidentally, if you use a newer version but need to see older versions for flash, then start like this:
sdkmanager --archivedversions
