No releases for Nano 2g SDK manager
Hi
I am trying to install am image to my Nano 2g via SDK, except it says no releases available for Ubuntu 20.04 ? The SDK pages says its compatible NVIDIA SDK Manager | NVIDIA Developer
I tried it on a Linux mint machine and got the same result.
I cant use a flashed SD as the Nano wont boot.
I am using SDK is because the Nano is displaying via serial, Warning: Find partition TBC NOT found !
Am missing something ?
I followed this guide:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
Only ubuntu 18.04 and 16.04 support sdkm to flash jetson.
I have just installed Ubuntu 20.04 because it says its supported !
Sorry that sdkmanager is a big tool that supports not only jetson. It also supports other platforms like DRIVE.
However, for jetson, only ubuntu 18.04 and 16.04 would work. For other platforms, 20.04 may work.
A user provides a workaround to let 20.04 able to run sdkmanager. Maybe you can try it.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
