I am not able to get the Profiler app to work on Ubuntu 18.04. CUDA 10.2 is installed.
An error has occurred. See the log file
~/.eclipse/org.eclipse.platform_4.4.1_1112099189_linux_gtk_x86_64/configuration/1592985003626.log.
Below is the log file message. May I know what is the error and how do I fix it?
!SESSION 2020-06-24 15:50:03.477 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.7
java.vendor=Ubuntu
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_SG
Command-line arguments: -os linux -ws gtk -arch x86_64 -data @noDefault
!ENTRY com.nvidia.cuda.ide.editor 4 0 2020-06-24 15:50:03.991
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.cuda.ide.editor [6]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.ui; bundle-version="[5.8.0.nvidia,5.8.1)"
-> Bundle-SymbolicName: org.eclipse.cdt.ui; bundle-version="5.8.0.nvidia-qualifier"; singleton:="true"
org.eclipse.cdt.ui [71]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.core; bundle-version="[5.2.0,6.0.0)"
-> Bundle-SymbolicName: org.eclipse.cdt.core; bundle-version="5.7.0.nvidia-qualifier"; singleton:="true"
org.eclipse.cdt.core [69]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.7))"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY com.nvidia.pgprof.application 4 0 2020-06-24 15:50:03.994
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.pgprof.application [10]
Unresolved requirement: Require-Bundle: com.nvidia.viper
-> Bundle-SymbolicName: com.nvidia.viper; bundle-version="10.2.0.201910240259"; singleton:="true"
com.nvidia.viper [12]
Unresolved requirement: Require-Bundle: com.nvidia.cuda.ide.editor; bundle-version="10.2.0"
-> Bundle-SymbolicName: com.nvidia.cuda.ide.editor; bundle-version="10.2.0.201910240259"; singleton:="true"
!ENTRY com.nvidia.viper 4 0 2020-06-24 15:50:03.997
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper [12]
!ENTRY com.nvidia.viper.application 4 0 2020-06-24 15:50:03.999
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper.application [13]
Unresolved requirement: Require-Bundle: com.nvidia.viper; bundle-version="10.2.0"
!ENTRY com.nvidia.viper.birt 4 0 2020-06-24 15:50:04.001
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper.birt [14]
!ENTRY org.eclipse.cdt.core 4 0 2020-06-24 15:50:04.004
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.core [69]
!ENTRY org.eclipse.cdt.ui 4 0 2020-06-24 15:50:04.005
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.ui [71]
!ENTRY com.nvidia.pgprof.application 2 0 2020-06-24 15:50:04.909
!MESSAGE Could not resolve module: com.nvidia.pgprof.application [10]
!ENTRY com.nvidia.viper 2 0 2020-06-24 15:50:04.909
!MESSAGE Could not resolve module: com.nvidia.viper [12]
!ENTRY org.eclipse.core.filesystem.java7 2 0 2020-06-24 15:50:04.909
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.java7 [84]
Unresolved requirement: Fragment-Host: org.eclipse.core.filesystem; bundle-version="[1.4.100,2.0.0)"
!ENTRY org.eclipse.cdt.ui 2 0 2020-06-24 15:50:04.910
!MESSAGE Could not resolve module: org.eclipse.cdt.ui [71]
!ENTRY com.nvidia.cuda.ide.editor 2 0 2020-06-24 15:50:04.910
!MESSAGE Could not resolve module: com.nvidia.cuda.ide.editor [6]
!ENTRY org.eclipse.cdt.core 2 0 2020-06-24 15:50:04.910
!MESSAGE Could not resolve module: org.eclipse.cdt.core [69]
!ENTRY com.nvidia.viper.birt 2 0 2020-06-24 15:50:04.910
!MESSAGE Could not resolve module: com.nvidia.viper.birt [14]
!ENTRY com.nvidia.viper.application 2 0 2020-06-24 15:50:04.910
!MESSAGE Could not resolve module: com.nvidia.viper.application [13]
!ENTRY org.eclipse.osgi 4 0 2020-06-24 15:50:04.911
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.nvidia.viper.application.application" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.birt.report.engine.ReportExecutor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.ui.ide.workbench.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
