I am connected via VNC to an Ubuntu Server 18.04 . When I open the Nvidia Visual Profiler I see: “An error has occurred. See the log file…”.
My config:
Running nvcc --version:
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Mon_Oct_12_20:09:46_PDT_2020
Cuda compilation tools, release 11.1, V11.1.105
Build cuda_11.1.TC455_06.29190527_0
Running nvidia-smi:
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| | | MIG M. |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 44C P8 10W / 70W | 0MiB / 15109MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
The log reports the following error:
eclipse.buildId=unknown
java.version=11.0.9.1
java.vendor=Ubuntu
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en
Command-line arguments: -os linux -ws gtk -arch x86_64 -data @noDefault
!ENTRY com.nvidia.cuda.ide.editor 4 0 2021-01-05 22:57:44.702
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.cuda.ide.editor [6]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.ui; bundle-version="[5.8.0.nvidia,5.8.1)"
-> Bundle-SymbolicName: org.eclipse.cdt.ui; bundle-version="5.8.0.nvidia-qualifier"; singleton:="true"
org.eclipse.cdt.ui [71]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.core; bundle-version="[5.2.0,6.0.0)"
-> Bundle-SymbolicName: org.eclipse.cdt.core; bundle-version="5.7.0.nvidia-qualifier"; singleton:="true"
org.eclipse.cdt.core [69]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.7))"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY com.nvidia.pgprof.application 4 0 2021-01-05 22:57:44.708
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.pgprof.application [10]
Unresolved requirement: Require-Bundle: com.nvidia.viper
-> Bundle-SymbolicName: com.nvidia.viper; bundle-version="11.1.0.202010130340"; singleton:="true"
com.nvidia.viper [12]
Unresolved requirement: Require-Bundle: com.nvidia.cuda.ide.editor; bundle-version="11.1.0"
-> Bundle-SymbolicName: com.nvidia.cuda.ide.editor; bundle-version="11.1.0.202010130340"; singleton:="true"
!ENTRY com.nvidia.viper 4 0 2021-01-05 22:57:44.715
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper [12]
!ENTRY com.nvidia.viper.application 4 0 2021-01-05 22:57:44.719
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper.application [13]
Unresolved requirement: Require-Bundle: com.nvidia.viper; bundle-version="11.1.0"
!ENTRY com.nvidia.viper.birt 4 0 2021-01-05 22:57:44.724
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: com.nvidia.viper.birt [14]
!ENTRY org.eclipse.cdt.core 4 0 2021-01-05 22:57:44.729
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.core [69]
!ENTRY org.eclipse.cdt.ui 4 0 2021-01-05 22:57:44.732
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.ui [71]
!ENTRY com.nvidia.viper.birt 2 0 2021-01-05 22:57:46.082
!MESSAGE Could not resolve module: com.nvidia.viper.birt [14]
!ENTRY com.nvidia.cuda.ide.editor 2 0 2021-01-05 22:57:46.082
!MESSAGE Could not resolve module: com.nvidia.cuda.ide.editor [6]
!ENTRY org.eclipse.core.filesystem.java7 2 0 2021-01-05 22:57:46.083
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.java7 [84]
Unresolved requirement: Fragment-Host: org.eclipse.core.filesystem; bundle-version="[1.4.100,2.0.0)"
!ENTRY com.nvidia.pgprof.application 2 0 2021-01-05 22:57:46.083
!MESSAGE Could not resolve module: com.nvidia.pgprof.application [10]
!ENTRY com.nvidia.viper.application 2 0 2021-01-05 22:57:46.084
!MESSAGE Could not resolve module: com.nvidia.viper.application [13]
!ENTRY com.nvidia.viper 2 0 2021-01-05 22:57:46.084
!MESSAGE Could not resolve module: com.nvidia.viper [12]
!ENTRY org.eclipse.cdt.core 2 0 2021-01-05 22:57:46.084
!MESSAGE Could not resolve module: org.eclipse.cdt.core [69]
!ENTRY org.eclipse.cdt.ui 2 0 2021-01-05 22:57:46.084
!MESSAGE Could not resolve module: org.eclipse.cdt.ui [71]
!ENTRY org.eclipse.osgi 4 0 2021-01-05 22:57:46.085
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.nvidia.viper.application.application" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.birt.report.engine.ReportExecutor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.ui.ide.workbench.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
