Hi all!
I am trying to get CUDA Toolkit working on my Windows 10 computer. Tried to build some of the example projects provided with the toolkit, but compilation fails every time:
1>------ Build started: Project: matrixMul, Configuration: Debug x64 ------
1>Compiling CUDA source file matrixMul.cu...
1>
1>C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1
1>Compiling CUDA source file matrixMul.cu…
1>
1>C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\0_Simple\matrixMul>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include" -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64/Debug/vc142.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/matrixMul.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\0_Simple\matrixMul\matrixMul.cu”
1>C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 10.1.targets(764,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" -gencode=arch=compute_35,code="sm_35,compute_35" -gencode=arch=compute_37,code="sm_37,compute_37" -gencode=arch=compute_50,code="sm_50,compute_50" -gencode=arch=compute_52,code="sm_52,compute_52" -gencode=arch=compute_60,code="sm_60,compute_60" -gencode=arch=compute_61,code="sm_61,compute_61" -gencode=arch=compute_70,code="sm_70,compute_70" -gencode=arch=compute_75,code="sm_75,compute_75" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.23.28105\bin\HostX86\x64” -x cu -I./ -I…/…/common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1/include” -I…/…/common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include” -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler “/wd 4819” -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Fdx64/Debug/vc142.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/matrixMul.cu.obj “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1\0_Simple\matrixMul\matrixMul.cu”” exited with code 1.
1>Done building project “matrixMul_vs2019.vcxproj” – FAILED.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
_Simple\matrixMul>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe" -gencode=arch=compute_30,code=\"sm_30,compute_30\" -gencode=arch=compute_35,code=\"sm_35,compute_35\" -gencode=arch=compute_37,code=\"sm_37,compute_37\" -gencode=arch=compute_50,code=\"sm_50,compute_50\" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio019\Community\VC\Tools\MSVC4.23.28105\bin\HostX86\x64" -x cu -I./ -I../../common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\/include" -I../../common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler "/wd 4819" -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdx64/Debug/vc142.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/matrixMul.cu.obj "C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1
1>
_Simple\matrixMul\matrixMul.cu"
1>C:\Program Files (x86)\Microsoft Visual Studio019\Community\MSBuild\Microsoft\VC\v160\BuildCustomizations\CUDA 10.1.targets(764,9): error MSB3721: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe" -gencode=arch=compute_30,code=\"sm_30,compute_30\" -gencode=arch=compute_35,code=\"sm_35,compute_35\" -gencode=arch=compute_37,code=\"sm_37,compute_37\" -gencode=arch=compute_50,code=\"sm_50,compute_50\" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio019\Community\VC\Tools\MSVC4.23.28105\bin\HostX86\x64" -x cu -I./ -I../../common/inc -I./ -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\/include" -I../../common/inc -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -Xcompiler "/wd 4819" -g -DWIN32 -DWIN32 -D_MBCS -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdx64/Debug/vc142.pdb /FS /Zi /RTC1 /MTd " -o x64/Debug/matrixMul.cu.obj "C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.1
1>
_Simple\matrixMul\matrixMul.cu"" exited with code 1.
1>Done building project "matrixMul_vs2019.vcxproj" -- FAILED.
I reinstalled the toolkit multiple times, tried combinations of VS2015, VS2017, VS2019, CUDA Toolkit 8, CUDA Toolkit 10, nvcc.exe gives the same error every time (increasing the verbosity in VS does not provide more info). Running the same command from the command line gives no output, only %errorlevel% = 1. I even tried reinstalling the thing with my antivirus uninstalled. The CUDA programs compiled on other computers run without problem.
Is there a log file or something like that, which can help me indentify the problem?
Thanks in advance,
Aron
