I am running deepstream via command line<deepstream-app -c deepstream_app_config.txt> providing rtsp url in the config file, I am unable to apply src-crop in the camera stream,
Environment
TensorRT Version: GPU Type: Nvidia Driver Version: CUDA Version: CUDNN Version: Operating System + Version: Python Version (if applicable): TensorFlow Version (if applicable): PyTorch Version (if applicable): Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Please provide complete information as applicable to your setup and your config file. Thanks Hardware Platform (Jetson / GPU) DeepStream Version JetPack Version (valid for Jetson only) TensorRT Version NVIDIA GPU Driver Version (valid for GPU only) Issue Type( questions, new requirements, bugs) How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
