I’m trying to use cuDNN 8.2.1.32 with CUDA 11 (I’ve tried 11.3.1 and 11.4.2). My code compiles and works fine without cuDNN but as soon as I try to use cuDNN, I get an error at runtime saying
Could not load library libcublasLt.so.10. Error: libcublasLt.so.10: cannot open shared object file: No such file or directory
Please make sure libcublasLt.so.10 is in your library path!
I do not have CUDA 10 anywhere on the server and I’m unable to figure out which part of the code is requesting libcublasLt.so.10 and why. I couldn’t find anything on googling the issue.
The above error indicates, libcublas is not installed. Could you please verify by dpkg -l | grep libcublas
Also please make sure you’ve installed CUDA correctly (Installation Guide Linux :: CUDA Toolkit Documentation) and the version is compatible with cuDNN 8.2. We always recommend you to please us the latest version.
Support Matrix :: NVIDIA Deep Learning cuDNN Documentation
I do have libcublas installed (it’s part of the standard CUDA Toolkit). My workaround for now is to install 2 CUDA Toolkits (11.3.1 and 10.2) so that cuDNN can find libcublasLt.so.10.
P.S. I installed both toolkit versions exactly the same way.
