https ://forums.developer.nvidia.com/t/external-monitor-not-detected-on-debian-11-with-rtx-3050-legion-5i-pro/198406
(I have the same problem as this guy, exact same issue.)
I have an hpec2075 ax laptop with AMD R5 APU and RTX 3050 eGPU.
My issue and problem is exact same except his got solved with optimus setting where as I don’t have optimus.
Preformatted textSame as him when I remove the /etc/X11/xorg.conf , that I generated with nvidia-xconfig, then my external display starts to work that is connected with the HDMI, else if I delete those file, then only my intenal laptop display would work.
Here, as you can see my inix -G output,
Here, my xorg.conf :
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 535.86.05
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
nvidia-smi
Thu Jul 20 23:47:43 2023
| NVIDIA-SMI 535.86.05 Driver Version: 535.86.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 ... Off | 00000000:01:00.0 On | N/A |
| N/A 46C P8 9W / 60W | 716MiB / 4096MiB | 44% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 951 G /usr/lib/Xorg 227MiB |
| 0 N/A N/A 1031 G /usr/bin/kwalletd5 1MiB |
| 0 N/A N/A 1097 G /usr/bin/ksmserver 1MiB |
| 0 N/A N/A 1099 G /usr/bin/kded5 1MiB |
| 0 N/A N/A 1100 G /usr/bin/kwin_x11 91MiB |
| 0 N/A N/A 1134 G /usr/bin/plasmashell 32MiB |
| 0 N/A N/A 1164 G ...b/polkit-kde-authentication-agent-1 1MiB |
| 0 N/A N/A 1166 G /usr/lib/xdg-desktop-portal-kde 1MiB |
| 0 N/A N/A 1317 G /usr/bin/kclockd 1MiB |
| 0 N/A N/A 1319 G /usr/lib/kdeconnectd 1MiB |
| 0 N/A N/A 1331 G /usr/bin/kaccess 1MiB |
| 0 N/A N/A 1337 G /usr/lib/DiscoverNotifier 1MiB |
| 0 N/A N/A 1338 G /usr/bin/kalendarac 1MiB |
| 0 N/A N/A 1350 G /usr/bin/kmix 1MiB |
| 0 N/A N/A 1451 G /usr/bin/akonadi_control 1MiB |
| 0 N/A N/A 1516 G /usr/bin/akonadi_akonotes_resource 1MiB |
| 0 N/A N/A 1517 G /usr/bin/akonadi_archivemail_agent 1MiB |
| 0 N/A N/A 1518 G /usr/bin/akonadi_birthdays_resource 1MiB |
| 0 N/A N/A 1519 G /usr/bin/akonadi_contacts_resource 1MiB |
| 0 N/A N/A 1520 G .../bin/akonadi_followupreminder_agent 1MiB |
| 0 N/A N/A 1521 G /usr/bin/akonadi_ical_resource 1MiB |
| 0 N/A N/A 1528 G /usr/bin/akonadi_indexing_agent 1MiB |
| 0 N/A N/A 1531 G /usr/bin/akonadi_maildir_resource 1MiB |
| 0 N/A N/A 1534 G /usr/bin/akonadi_maildispatcher_agent 1MiB |
| 0 N/A N/A 1535 G /usr/bin/akonadi_mailfilter_agent 1MiB |
| 0 N/A N/A 1536 G /usr/bin/akonadi_mailmerge_agent 1MiB |
| 0 N/A N/A 1537 G /usr/bin/akonadi_migration_agent 1MiB |
| 0 N/A N/A 1538 G /usr/bin/akonadi_newmailnotifier_agent 1MiB |
| 0 N/A N/A 1539 G /usr/bin/akonadi_notes_agent 1MiB |
| 0 N/A N/A 1544 G /usr/bin/akonadi_sendlater_agent 1MiB |
| 0 N/A N/A 1547 G /usr/bin/akonadi_unifiedmailbox_agent 1MiB |
| 0 N/A N/A 1712 G /usr/bin/kitty 2MiB |
| 0 N/A N/A 1758 G /usr/lib/firefox/firefox 131MiB |
| 0 N/A N/A 2392 G /usr/bin/spectacle 9MiB |
| 0 N/A N/A 2770 G ...,WinRetrieveSuggestionsOnlyOnDemand 89MiB |
| 0 N/A N/A 3013 G /usr/bin/dolphin 1MiB |
| 0 N/A N/A 3041 G /usr/bin/kate 1MiB |
xrandr
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
Earlier when I deleted the xorg.conf, xrandr was detecting both my displays.
