Unable to using RayTracing in ISAAC SIM, not sure if the problem with GPU of T1000 with 4GB memory
I saw that T1000 support the RayTracing in its introduction, but I cannot use the ISAAC SIM no matter the datest version or old version, I also updata my GPU driver, but it didn’t work. Can anyone help me? It is so emergency.
2023-12-24 06:39:28 [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
2023-12-24 06:39:28 [Error] [gpu.foundation.plugin] - The driver is not installed properly and requires a clean re-install.
2023-12-24 06:39:28 [Error] [gpu.foundation.plugin] - Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
2023-12-24 06:39:28 [Error] [gpu.foundation.plugin] - The driver cannot enumerate any GPU: driver, display, TCC mode or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
Hi. I don’t think the T1000 is supported. It does not have RT Cores to fully support RTX rendering and does not have enough VRAM.
