When i run
QT_QPA_PLATFORM=wayland dbus-run-session kwin_wayland --xwayland “plasmashell -p org.kde.plasma.mobileshell”
I get following error
src/gbm\_drv\_common.c:130: GBM-DRV error (get\_bytes\_per\_component): Unknown or not supported format: 808669784
From Kwin developer
DRM_FORMAT_XRGB2101010
Version : 550.54.14
Kwin version : 6.0.2
My nixos version nixos/flake.lock at 3c78f3a2c12762dd87f082e386e53cdbc44d857e · mrdev023/nixos · GitHub
And nvidia conf
{ config, pkgs, ... }:
# Enable OpenGL
hardware.opengl = {
enable = true;
driSupport = true;
driSupport32Bit = true;
# Load nvidia driver for Xorg and Wayland
services.xserver.videoDrivers = ["nvidia"];
hardware.nvidia = {
# Modesetting is required.
modesetting.enable = true;
# Nvidia power management. Experimental, and can cause sleep/suspend to fail.
powerManagement.enable = false;
# Fine-grained power management. Turns off GPU when not in use.
# Experimental and only works on modern Nvidia GPUs (Turing or newer).
powerManagement.finegrained = false;
# Use the NVidia open source kernel module (not to be confused with the
# independent third-party "nouveau" open source driver).
# Support is limited to the Turing and later architectures. Full list of
# supported GPUs is at:
# https://github.com/NVIDIA/open-gpu-kernel-modules#compatible-gpus
# Only available from driver 515.43.04+
# Currently alpha-quality/buggy, so false is currently the recommended setting.
open = false;
# Enable the Nvidia settings menu,
# accessible via `nvidia-settings`.
nvidiaSettings = true;
# Optionally, you may need to select the appropriate driver version for your specific GPU.
package = config.boot.kernelPackages.nvidiaPackages.latest;
