I am experimenting with creating an MLAG using GNS3.
I would like to know about the specifications regarding MLAG.
I have set up the MLAG so that under normal conditions it is bonded on the downlink to each Debian server.
Since the configuration is L2Flat, the backup-ip uses the management IP of the vrf MGMT on eth0.
Suppose that one of the links from each leaf switch to the server is down and I have to go through peerlink.
Left: Normal, Right: Impaired
My assumption was that debian12.4-1 and debian12.4-1 could communicate without problems via peerlink, but they cannot.
With my current setup, it seems that no traffic is passing between peerlink.
What is leaking?
config
- leaf01(leaf02): Cumulus version 5.4.0
nv set system hostname leaf01(leaf02 is leaf02)
nv set interface eth0 ip address 192.168.255.1/24(leaf02 is 192.168.255.2/24)
nv set interface bond1 bond member swp1
nv set interface bond2 bond member swp2
nv set interface bond1 bond mlag id 1
nv set interface bond2 bond mlag id 2
nv set interface bond1-2 bridge domain br_default
nv set interface peerlink bond member swp5-6
nv set interface bond1-2 bond mode static
nv set bridge domain br_default vlan 200,500
nv set bridge domain br_default untagged 100
nv set mlag mac-address 44:38:39:BE:EF:AA
nv set mlag backup 192.168.255.2 vrf mgmt(leaf02 is 192.168.255.1)
nv set mlag peer-ip linklocal
nv config apply
other show status
cumulus@leaf01:mgmt:~$ nv show mlag
operational applied
enable on
debug off
init-delay 180
mac-address 44:38:39:be:ef:aa 44:38:39:BE:EF:AA
peer-ip fe80::e31:9dff:fea9:5 linklocal
priority 32768 32768
[backup] 192.168.255.2 192.168.255.2
backup-active True
backup-reason
local-id 0c:07:85:52:00:05
local-role primary
peer-alive True
peer-id 0c:31:9d:a9:00:05
peer-interface peerlink.4094
peer-priority 32768
peer-role secondary
cumulus@leaf01:mgmt:~$ nv show mlag consistency-checker global
Parameter LocalValue PeerValue Conflict Summary
anycast-ip - - -
bridge-priority 32768 32768 -
bridge-stp on on -
bridge-type vlan-aware vlan-aware -
clag-pkg-version 1.6.0-cl5.4.0u4 1.6.0-cl5.4.0u4 -
clag-protocol-vers… 1.6.0 1.6.0 -
peer-ip fe80::e31:9dff:fea… fe80::e31:9dff:fea… -
peerlink-master br_default NOT-SYNCED -
peerlink-mtu 9216 9216 -
peerlink-native-vl… 100 100 -
peerlink-vlans 100, 200, 500 100, 200, 500 -
redirect2-enable yes yes -
system-mac 44:38:39:be:ef:aa 44:38:39:be:ef:aa -
Thank you for your cooperation.
