We have random Link Up / Down events for 2 x MT27700 cards connected to 2x100G Uplinks, what are configured as 2 separate VLAN’s with own gateways, both are connected to Juniper switch. Here is sample config of our netplan at ubuntu 18.04 https://pastebin.com/2P2ELS0N
dmesg
[79546.319000] mlx5_core 0000:04:00.1 eth0: Link down
[79551.219139] mlx5_core 0000:04:00.1 eth0: Link up
[109933.693829] mlx5_core 0000:04:00.1 eth0: Link down
[109938.643748] mlx5_core 0000:04:00.1 eth0: Link up
Each card connected to own NUMA, and we are using iface binding to route outgoing traffic with eth0 or eth1, but this link / up down events happens even if server is IDLE.
Here is the list of fixes we tried and what DIDN’T HELP:
We changed NIC cards to 2 xMT28800
We tried Ubuntu 18.04, 19.04, 19.10, Centos 8 with latest MLNX_OFED_LINUX-4.7-1.0.0.1 x86_64
We tried built in kernel drivers 4.15, 5.0.x, 5.1.x, 5.2.x, 5.3.x
We tried to replace all optics
We tried to change ports on switch
We tried to replace ALL SERVER hardware (MB, CPU, RAM, Power Supply)
We tried to disable gro, lro, tso.
Server specs
CPU: Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
RAM: 256GB
Manufacturer: Supermicro
Product Name: X9DRi-LN4+/X9DR3-LN4+
Dual MT27700 2x100G (We also tried MT28800 2x100G, but it didn’t fix it)
Could you say please, what else we may try to fix it?
P.S.: we also created Mellanox Case # 00703035 , but we are not subscribed for now, for your premium support service.
Many thanks for posting your inquiry on the Mellanox Community.
Based on the information provided, it looks like this issue will need additional debugging and troubleshooting which we normally do through our official support process. We see that an official support case is opened so we want to continue to provide support through that ticket.
In the meantime, please make sure the following is in place:
Latest f/w installed on the adapters
Cables used based on the latest RN which lists the validated and tested cables:
Seems our case closed, as we don’t have live contract for support with you, as we are just rented server with your hardware and got into this issue, not re-sellers or buyers of your hardware.
We tried ifupdown before with manual route adding for second NIC like
ip route add 1.1.1.0/29 dev eth0 src 1.1.1.2 table 102
ip route add default via 1.1.1.1 dev eth0 table 102
ip rule add from 1.1.1.2/29 table 102
ip rule add to 1.1.1.2/29 table 102
we tried to reinstall many times ubuntu 18.04, 19.04, 19.10, centos 8, we also tried upstream kernles 5.1.x, 5.2.x, 5.3.x, with your drivers or builtin.
we don’t have any anomalies in log, only these messages. datacenter also reported, that they don’t have any issues on their side.
Network topology
Our Juniper ex 4650 ---------------- Provider Cisco Router
Your Server
Switch
RE-EX4650-48Y-8C
Software Version 18.4R1-S3.1
We can provide access to our server if you wish or provide further info you’ll request.
