Based on development needs, my company requires jetpack 5.1.3 and 6.0, so it needs to update SPI flash (short force_recovery and ground), but it has a failure rate of about 10%. Do you have any suggestions or solutions?
Thanks,
Allen Lee
Thanks,
Allen Lee
Which Jetson platform? AGX Orin or Orin NX?
Orin NX . Thanks.
Hi allenlee1,
Are you using the devkit or custom board for Orin NX?
Do you mean that you want to flash the QSPI only?
What do you mean about the failure?
Is it about failing to enter into force recovery?
Or it is about flashing failed?
1.Use our custom board.
2.Yes, just flash the QSPI only.
3.We update the SPI flash 30 pieces , 27 pieces success, but 3 pieces fail.
Please run the following command to flash QSPI only for Orin NX.
$ sudo ./flash.sh -c bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
Please share the flash failed log of those 3 pieces.
error.txt (23.9 KB)
Please refer to the attachment. There are two items with the same error message. The other item is that the SPI NOR Flash cannot be found.
Please share the full error log instead of part of them.
Would it work if you reflash those 3 pieces?
