Update to Jetpack 6.2 Problem
Hi everyone,
A few months ago, I bought an OStream GenRunner Node—a board with a Jetson Orin Nano 4GB module mounted on it. I later discovered the Carrier Board from Seeedstudio (the reComputer J401) and bought it since the OStream’s carrier board was very poor quality. After connecting the board to the monitor, I found it was running Ubuntu 20.04 (likely Jetpack 5.1.3). I wanted to update it to Jetpack 6.2 (or a version with Ubuntu 22.04), but every attempt to flash the new firmware resulted in problems. Sometimes I got “can’t find PARTUUID,” other times just a blinking “_” symbol on screen, or “Attempting Recovery Boot,” among other issues.
I have also tried with the specific version distributed by Seeedstudio in Flash Jetpack | Seeed Studio Wiki but without success. I’m now at a loss because I cannot find a solution.
Please help me.
Hi a.catalano8,
It seems you are using the custom carrier board for Orin Nano.
Do you get the custom BSP package from your vendor to flash your board?
If so, please share the full flash log for further check.
Hi @KevinFFF,
if you go to https://wiki.seeedstudio.com/reComputer_J4012_Flash_Jetpack/ there is a tar.gz developed by Seedstudio (or at least should be). When I did the flash following their tutorial this is the log I get.
flash_3-5_0_20250507-164156.log (41.1 KB)
But when I try to connect the Jetson to the monitor I receive the same results:
The BSP is a package I should find on their website?
/home/angelo/nvidia/hw_target/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
From the log you shared, it seems you are using Jetpack 5.1.3 rather than Jetpack 6.2.
Please confirm you download the correct custom BSP package of Jetpack 6.2 or request your vendor for the detailed steps to setup them.
@KevinFFF My bad, here there is the log obtained when I tried to flash Jetpack 6.0 using the files given me by the SeedStudio:
flash_3-2_0_20250512-112428.log (54.7 KB)
Do you want to use JP6.0 or JP6.2?
Flash is successful
Reboot device
Cleaning up...
From the flash log you shared, it seems flash is successful.
Please share the full serial console log for further check.
And I don’t know why the configuration file(p3768-0000-p3767-0000-a0.conf) missing in your case.
/home/omni/flash_scripts/package/mfi_recomputer-orin-j401/recomputer-orin-j401.conf: line 29: /home/omni/flash_scripts/package/mfi_recomputer-orin-j401/p3768-0000-p3767-0000-a0.conf: No such file or directory
I’d advise you to also reach out to your vendor concerning similar issues. The problem seems to be specific to your custom carrier board and custom BSP package, which we don’t have on hand
