Upgrade Orin AGX 64GB Development Kit
I have bricked my 945-13730-0055-000 Developer Kit. I used sdkmanager + SDK 6.
I selected P3701-0005 module + P3737-0000 carrier board. The download then slowers and stops at 99%. The system becomes unbootable. I tried several Linux hosts (ubuntu 20.04 and 22.04 version). I need heldto recover my device
BR
Bernd
This topic belongs in the Jetson forums, I will move it over for you.
Cheers,
Tom
Follow these steps:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/IN/QuickStart.html#to-flash-the-jetson-developer-kit-operating-software
BSP can be downloaded at:
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v2.0/release/jetson_linux_r36.2.0_aarch64.tbz2
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v2.0/release/tegra_linux_sample-root-filesystem_r36.2.0_aarch64.tbz2
Thanks Dave,
after several tries with sdkmanager i finally suceeded, but I will try this method for the ssd image flash.
Same problem (slower download from 85% is the same when I install cuda via sdkmanager) so I installed jetson pack locally with apt install
BR
Bernd
Thanks, that worked.
After installation I ran apt-get update & apt upgrade, after reboot the docker image fail to start
BR Bernd
