Installation Failed while updating Jetpack using SDK Manager
Hi
I was trying to update the Jetpack version from 5 to 6 on AGX Orin 64gb dev kit using the SDK Manager on a host machine (running Ubuntu 20). The SDK manager shows installation failed for the Target Components.
Below are the console logs:
15:14:33 INFO: Flash Jetson Linux - flash: might be timeout in USB write.
15:14:33 ERROR: Flash Jetson Linux - flash: Error: Return value 3
15:14:33 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
15:14:33 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
15:14:33 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.iroongta.sh; [error]: --- Error: Reading board information failed.
15:14:33 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
15:14:33 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
15:14:33 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 14s ]
15:14:33 ERROR: Flash Jetson Linux - flash: command terminated with error
15:14:33 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
15:33:05 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS to /home/iroongta/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS
15:33:05 INFO: Flash Jetson Linux - flash: change working directory to /home/iroongta/nvidia/nvidia_sdk/JetPack_6.0_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
15:33:05 INFO: Flash Jetson Linux - flash: [OEMPreconfig] Password for L4T new user raggle:
15:33:05 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode ...
15:33:05 INFO: Flash Jetson Linux - flash: *** Checking target board connection ...
15:33:05 INFO: Flash Jetson Linux - flash: *** Reading ECID ...
15:33:05 INFO: Flash Jetson Linux - flash: *** Reading EEPROM ...
15:33:06 INFO: Flash Jetson Linux - flash: [ 0.0797 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
15:33:06 INFO: Flash Jetson Linux - flash: [ 0.0833 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
15:33:06 INFO: Flash Jetson Linux - flash: [ 0.3417 ] WARNIN
15:33:06 INFO: Flash Jetson Linux - flash: [ 0.3808 ] Generating br-bct
15:33:06 INFO: Flash Jetson Linux - flash: [ 0.6019 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
15:33:06 INFO: Flash Jetson Linux - flash: c
15:33:16 INFO: Flash Jetson Linux - flash: OR:
15:33:16 ERROR: Flash Jetson Linux - flash: command terminated with error
SDK Manager gives you the option of dumping the log as a zip file.
SDKM_logs_JetPack_6.0_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2024-06-12_15-28-49.zip (242.6 KB)
Here it is yes.
Issue is resolved. I tried a different USB port and it worked. Thanks
