Hi folks, I’m facing issues trying to upgrade the DGX OS from 4.1.0 to 5+. When I try to run sudo nvidia-release-upgrade --force
it tells me
$ sudo nvidia-release-upgrade --force
WARNING: The following packages are installed, but have no 20.04 upgrade path.
They will be uninstalled during the release upgrade process.
libcudnn7 libcudnn7-dev libcudnn7-doc
'restricted' distribution component is already enabled for all sources.
Reading package lists... Done
Building dependency tree
Reading state information... Done
libc6:i386 is already the newest version (2.27-3ubuntu1.5).
The following packages were automatically installed and are no longer required:
libnvidia-gl-430 libnvidia-gl-440 libnvidia-gl-450
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
Package: *
Pin: release l=Base OS Repository
Pin-Priority: 600
Package: *
Pin: release l=Base OS Updates Repository
Pin-Priority: 600
Package: *
Pin: release l=NVIDIA CUDA
Pin-Priority: 580
Package: cuda-drivers
Pin-Priority: -1
Package: nsight-compute
Pin: origin *ubuntu.com*
Pin-Priority: -1
Package: nsight-systems
Pin-Priority: -1
Package: nvidia-fabricmanager-*
Pin-Priority: 600
Package: libnvidia-nscq-*
Pin-Priority: 600
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
The thing is, I have already done sudo apt update
and sudo apt -y full-upgrade
I guess this because of ‘40 not upgraded.’ and investigate.
For example, dgx-plymouth is depended on nvidia-plymouth,
and nvidia-plymouth is depended on plymouth-theme-spinner.
But plymouth-theme-spinner seems to be not provided for Ubuntu18.04 no more.
What should I do?
Can I delete ‘not upgraded packages’ and install after upgrade?
Some help on this would be great! Thanks a lot.
