We are designing a Xavier AGX Custom carrier board, From the OEM Developer guide it is clear that for initial boot up and recovery the USB 2.0 Port 0 (Pin F12 and F13) should be used in device mode . We have a doubt that whether the same port can be used as a device mode after boot up? We are trying to enumerate Xavier AGX as USB 2.0 Storage/memory device. Is that possible? Do any existing example is available for that? I have attached schematic for the USB 2.0 Connection. for reference.
Yes, it is possible. Just need to configure the device tree.
we are trying to enumerate Xavier AGX as USB 2.0 Storage/memory device.
NV devkit already provides similar case on device mode port. Better checking with nv devkit for this function first. Not sure if that is what you want.
