Here is the more detailed version of lspci:
~$ sudo lspci -s 3:00.0 -vvv
03:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XH CI])
Subsystem: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINT x+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx -
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 130
Region 0: Memory at 13000000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [90] MSI-X: Enable+ Count=8 Masked-
Vector table: BAR=0 offset=00001000
PBA: BAR=0 offset=00001080
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 unlimited
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- A CSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- A CSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- A CSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 13-00-00-00-92-43-14-08
Capabilities: [150 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Kernel driver in use: xhci_hcd
The camera is definitely a USB 3.0 only camera. I had also tried with a two USB sticks, one regular (I assume it should be usb2) and another USB stick which has USB 3.0 support. None of them seems to work with the extension board. The board has four “Renesas / NEC - µPD720202” chipset. The full specs should be found here: https://www.startech.com/ca/Cards-Adapters/USB-3.0/Cards/PCI-Express-USB-3-Card-4-Dedicated-Channels-4-Port~PEXUSB3S44V. This is the board that I do have.
I had run dmesg today, and I noticed some errors (see lines 44, 70, 96 and 122):
[ 3.267259] NET: Registered protocol family 24
[ 3.267308] usbcore: registered new interface driver r8152
[ 3.267337] usbcore: registered new interface driver asix
[ 3.267361] usbcore: registered new interface driver ax88179_178a
[ 3.267382] usbcore: registered new interface driver cdc_ether
[ 3.267417] usbcore: registered new interface driver smsc95xx
[ 3.267442] usbcore: registered new interface driver net1080
[ 3.267465] usbcore: registered new interface driver cdc_subset
[ 3.267486] usbcore: registered new interface driver zaurus
[ 3.267526] usbcore: registered new interface driver cdc_ncm
[ 3.267541] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.267811] ehci-pci: EHCI PCI platform driver
[ 3.267946] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 3.267963] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
[ 4.138510] tegradc tegradc.1: hdmi: plugged
[ 4.146391] smmu_dump_pagetable(): fault_address=0x00000000fdd04000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 4.160816] mc-err: (0) csr_afir: EMEM decode error on PDE or PTE entry
[ 4.170476] mc-err: status = 0x6000000e; addr = 0xfdd04000
[ 4.179217] mc-err: secure: no, access-type: read, SMMU fault: nr-nw-s
[ 4.190126] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.200158] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.210641] usb usb1: Product: xHCI Host Controller
[ 4.218823] usb usb1: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.228170] usb usb1: SerialNumber: 0000:03:00.0
[ 4.236415] xHCI xhci_add_endpoint called for root hub
[ 4.236423] xHCI xhci_check_bandwidth called for root hub
[ 4.236510] hub 1-0:1.0: USB hub found
[ 4.243675] hub 1-0:1.0: 1 port detected
[ 4.251161] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 4.259864] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[ 4.270846] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.281196] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.291994] usb usb2: Product: xHCI Host Controller
[ 4.300450] usb usb2: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.310005] usb usb2: SerialNumber: 0000:03:00.0
[ 4.318324] xHCI xhci_add_endpoint called for root hub
[ 4.318330] xHCI xhci_check_bandwidth called for root hub
[ 4.318417] hub 2-0:1.0: USB hub found
[ 4.325661] hub 2-0:1.0: 1 port detected
[ 4.407979] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 4.416743] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[ 4.434553] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.436437] smmu_dump_pagetable(): fault_address=0x00000000fdd0e000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 4.436443] mc-err: (0) csr_afir: EMEM decode error on PDE or PTE entry
[ 4.436448] mc-err: status = 0x6000000e; addr = 0xfdd0e000
[ 4.436453] mc-err: secure: no, access-type: read, SMMU fault: nr-nw-s
[ 4.490192] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.501210] usb usb3: Product: xHCI Host Controller
[ 4.509868] usb usb3: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.519661] usb usb3: SerialNumber: 0000:04:00.0
[ 4.528261] xHCI xhci_add_endpoint called for root hub
[ 4.528268] xHCI xhci_check_bandwidth called for root hub
[ 4.528349] hub 3-0:1.0: USB hub found
[ 4.535846] hub 3-0:1.0: 1 port detected
[ 4.543618] xhci_hcd 0000:04:00.0: xHCI Host Controller
[ 4.552564] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[ 4.563742] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.574224] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.585103] usb usb4: Product: xHCI Host Controller
[ 4.593599] usb usb4: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.603239] usb usb4: SerialNumber: 0000:04:00.0
[ 4.611641] xHCI xhci_add_endpoint called for root hub
[ 4.611647] xHCI xhci_check_bandwidth called for root hub
[ 4.611724] hub 4-0:1.0: USB hub found
[ 4.619037] hub 4-0:1.0: 1 port detected
[ 4.697974] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 4.706726] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 5
[ 4.724377] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.726358] smmu_dump_pagetable(): fault_address=0x00000000fdd18000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 4.726363] mc-err: (0) csr_afir: EMEM decode error on PDE or PTE entry
[ 4.726368] mc-err: status = 0x6000000e; addr = 0xfdd18000
[ 4.726372] mc-err: secure: no, access-type: read, SMMU fault: nr-nw-s
[ 4.779492] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.790417] usb usb5: Product: xHCI Host Controller
[ 4.798988] usb usb5: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.808704] usb usb5: SerialNumber: 0000:05:00.0
[ 4.817216] xHCI xhci_add_endpoint called for root hub
[ 4.817222] xHCI xhci_check_bandwidth called for root hub
[ 4.817302] hub 5-0:1.0: USB hub found
[ 4.824785] hub 5-0:1.0: 1 port detected
[ 4.832574] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 4.841578] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
[ 4.852886] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.863564] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.874704] usb usb6: Product: xHCI Host Controller
[ 4.883521] usb usb6: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 4.893521] usb usb6: SerialNumber: 0000:05:00.0
[ 4.902285] xHCI xhci_add_endpoint called for root hub
[ 4.902291] xHCI xhci_check_bandwidth called for root hub
[ 4.902370] hub 6-0:1.0: USB hub found
[ 4.910072] hub 6-0:1.0: 1 port detected
[ 4.987982] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 4.997160] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 7
[ 5.015262] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.017208] smmu_dump_pagetable(): fault_address=0x00000000fdd22000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 5.017213] mc-err: (0) csr_afir: EMEM decode error on PDE or PTE entry
[ 5.017217] mc-err: status = 0x6000000e; addr = 0xfdd22000
[ 5.017221] mc-err: secure: no, access-type: read, SMMU fault: nr-nw-s
[ 5.071873] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.083054] usb usb7: Product: xHCI Host Controller
[ 5.091850] usb usb7: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 5.101789] usb usb7: SerialNumber: 0000:06:00.0
[ 5.110535] xHCI xhci_add_endpoint called for root hub
[ 5.110542] xHCI xhci_check_bandwidth called for root hub
[ 5.110633] hub 7-0:1.0: USB hub found
[ 5.118330] hub 7-0:1.0: 1 port detected
[ 5.126300] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 5.135463] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 8
[ 5.146895] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.157645] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.168815] usb usb8: Product: xHCI Host Controller
[ 5.177603] usb usb8: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[ 5.187541] usb usb8: SerialNumber: 0000:06:00.0
[ 5.196281] xHCI xhci_add_endpoint called for root hub
[ 5.196287] xHCI xhci_check_bandwidth called for root hub
[ 5.196366] hub 8-0:1.0: USB hub found
[ 5.204047] hub 8-0:1.0: 1 port detected
[ 5.278147] tegra_xusb_read_usb_calib: usb_calib0 = 0x0a20a413
[ 5.289404] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[ 5.299979] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (124416 Bytes)
[ 5.312167] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080040000 mapped 0xffffff8000359000 (124416 Bytes)
[ 5.312447] usbcore: registered new interface driver cdc_acm
[ 5.312449] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.312485] usbcore: registered new interface driver cdc_wdm
[ 5.312607] usbcore: registered new interface driver usb-storage
[ 5.312697] usbcore: registered new interface driver usbserial
[ 5.312728] usbcore: registered new interface driver ftdi_sio
[ 5.312749] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.312917] usbcore: registered new interface driver option
[ 5.312934] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.313143] usbcore: registered new interface driver pl2303
[ 5.313160] usbserial: USB Serial support registered for pl2303
[ 5.313204] usbcore: registered new interface driver nvshieldled
[ 5.313207] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[ 5.313483] tegra USB phy - inst[0] platform info:
[ 5.313485] port_otg: yes
[ 5.313486] has_hostpc: yes
[ 5.313488] phy_interface: USB_PHY_INTF_UTMI
[ 5.313489] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 5.313491] qc2_voltage: 0
[ 5.313492] vbus_pmu_irq: 0
[ 5.313494] charging: enabled
[ 5.313495] remote_wakeup: disabled
[ 5.318282] regulator_get() failed for (tegra-udc.0,usb_bat_chg), -19
[ 5.318290] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 5.318672] usbcore: registered new interface driver xpad
[ 5.318704] usbcore: registered new interface driver usb_acecad
[ 5.318734] usbcore: registered new interface driver aiptek
[ 5.318763] usbcore: registered new interface driver gtco
[ 5.318794] usbcore: registered new interface driver hanwang
[ 5.318825] usbcore: registered new interface driver kbtab
[ 5.318874] usbcore: registered new interface driver wacom
[ 5.400775] max77620-rtc max77620-rtc.1: rtc core: registered max77620-rtc as rtc1
[ 5.621637] tegra-xhci tegra-xhci: num_hsic_port 0
[ 5.632091] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[ 5.646728] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 5.656181] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 9
[ 5.667917] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[ 5.677238] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.678082] Wake51 for irq=118
[ 5.678085] Enabling wake51
[ 5.678378] Wake16 for irq=34
[ 5.678380] Enabling wake16
[ 5.679102] tegra-rtc 7000e000.rtc: rtc core: registered tegra-rtc as rtc0
[ 5.679321] i2c /dev entries driver
[ 5.680939] [OV5693]: probing v4l2 sensor.
[ 5.681223] ov5693 6-0036: Failed to allocate eeprom reg map: -22
[ 5.748067] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.758789] usb usb9: Product: Nvidia xHCI Host Controller
[ 5.767725] usb usb9: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 5.777365] usb usb9: SerialNumber: tegra-xhci
[ 5.785482] xHCI xhci_add_endpoint called for root hub
[ 5.785489] xHCI xhci_check_bandwidth called for root hub
[ 5.785578] hub 9-0:1.0: USB hub found
[ 5.792780] hub 9-0:1.0: 5 ports detected
[ 5.847917] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[ 5.857231] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 10
[ 5.868300] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.878713] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.889515] usb usb10: Product: Nvidia xHCI Host Controller
[ 5.898577] usb usb10: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[ 5.908330] usb usb10: SerialNumber: tegra-xhci
[ 5.916540] xHCI xhci_add_endpoint called for root hub
[ 5.916546] xHCI xhci_check_bandwidth called for root hub
[ 5.916623] hub 10-0:1.0: USB hub found
[ 5.923948] hub 10-0:1.0: 4 ports detected
[ 5.987968] Wake44 for irq=81
[ 5.994387] Wake40 for irq=53
[ 6.000745] Wake41 for irq=53
[ 6.007057] Wake42 for irq=53
[ 6.013320] Wake43 for irq=53
[ 6.358269] usb 10-1: new SuperSpeed USB device number 2 using tegra-xhci
[ 6.389246] usb 10-1: New USB device found, idVendor=0955, idProduct=09ff
[ 6.399280] usb 10-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 6.409702] usb 10-1: Product: USB 10/100/1000 LAN
[ 6.417701] usb 10-1: Manufacturer: Nvidia
[ 6.425046] usb 10-1: SerialNumber: 000001000000
[ 6.514675] virtual_init
[ 6.520983] [IMX135] sensor driver loading
[ 6.528345] [imx132] sensor driver loading
[ 6.535609] [ar0261] sensor driver loading
[ 6.542874] ov7695 sensor driver loading
[ 6.549946] mt9m114 sensor driver loading
[ 6.557130] [ov10823] sensor driver loading
[ 6.564375] usb 10-1: reset SuperSpeed USB device number 2 using tegra-xhci
[ 6.564569] usbcore: registered new interface driver uvcvideo
[ 6.564571] USB Video Class driver (1.1.1)
[ 6.592117] max77620-power-off max77620-power-off.4: Event recorder REG_NVERC : 0x0
[ 6.603358] FAN dev name: pwm-fan
[ 6.609906] FAN:gpio request success.
[ 1363.820248] [09-13 11:59:10.168] dhd_dump_eapol_4way_message: ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 1370.329692] smmu_dump_pagetable(): fault_address=0x0000000000000000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 1370.341317] mc-err: (0) csw_afiw: EMEM decode error on PDE or PTE entry
[ 1370.348176] mc-err: status = 0x60010031; addr = 0x00000000
[ 1370.354023] mc-err: secure: no, access-type: write, SMMU fault: nr-nw-s
[ 1413.593431] [09-13 11:59:59.941] wl_cfg80211_disconnect: Reason 2
[ 1413.613178] wl_is_linkdown : Link down Reason : WLC_E_LINK
Again I do not know if the errors are related or not, but the last one (line 217) happen when I was connecting the USB 3.0 thumb drive. I hope this shed some light to the problem. I really appreciate your time.
