I consider Xavier NX custom board.
I wanna make several information clear about USB camera.
First, I’ve seen RTS 5489-GR is reference on following link and carrier board designs file’s schematic.
=> Porting USB → Required Device Tree Changes
And Product Design Guide comments both RTS 5420(Ch3-2_p.8) and RTS 5489-GR(Ch.3_p.7).
Following Forums answer RTS 5420 is reference.
=> NVIDIA Jetson NX Developer Board Part Unavailable - RTS5489-GR
Can I use both RTS 5489-GR and RTS 5420?
Or can I use only RTS 5420?
Second, I wanna connect 3 or 4 multple USB3.0 (USB3.1 gen 1) cameras through SSHUB.
All USB port A on Developer Kit were specified for USB 3.0 from carrier board specification.
So, It is fine with carrier board design, but I have to check this Note.
Note: Some non-compliant USB 3.0 devices will not function correctly unless USB 3.1 Gen2 is disabled.
What USB 3.0 is compliant or not? How can I check it?
Third, I have a question for bandwidth if the second question is possible.
I refer following forum and Xavier Series Soc Reference Manual.
=> How to change USB3 port speed to gen1
Each dual port shares 10 Gbps. It means It can be possible to use 4 port of USB 3.0 Cameras for bandwidth side.
But, I’m not sure it from following comments : SuperSpeedPlus hub, due to scheduling policy reasons each SuperSpeed device may not be able sustain the full SuperSpeed unit bandwidth if the other is device is active.
For example, port 1 ans port 2 share 10 Gbps total bandwidth.
And port 1 and port 2 connect to USB 3.0 Camera with 5 Gbps respectively.
This bandwidth looks fine.
And then I wanna check device access or scheduling side are fine or not.
Can I get the image data same time from each camera?
