USB Boot failing at reboot
Hello, I have a new Jetson Thor and followed guide to flash USB with Jetpack and it goes through the first few steps and then fails to properly reboot on the last one. I didn’t have it connected to ethernet and then did it again with it connected and still same result. Have tried multiple times.
I am facing the same issue. I tried everything I could but I am unable to resolve this and go-beyond this point. Any help will be appreciated.
These might help:
First, when Thor reboots hit Esc several times until it goes in to bios setup. Then go into one of the boot menu items and change the boot order to put the nvme at the top. Save then Reset.
Second, you may need to follow this guide to do subsequent to the initial usb stick flash.
Hi @jesse75
Since I don’t get your last reply on your old topic,
I just wonder… are you sure your flash with Jetpack really succeeded?
So far I don’t see any flash log /commands from your side.
I ended up doing the BSP setup and it worked. All set! It seems like the USB install is buggy. Had the issue on both Thors I got, now they are fine though.
I would try doing the BSP setup and make sure you are not using the dev port and just the regular USB-C and connecting it to the USB 2.0 on machine doing the flashing.
Greetings, I believe I’m having the same problem because my flashed Jetson Thor will not boot correctly. What are the steps to do a BSP setup?
