On my custom board, I wanted to enable the usb2-0(micro-usb) & usb3-1. With the L4T-R32.1, the usb2-0 worked. But if I modified the device-tree as https://devtalk.nvidia.com/default/topic/1049988/jetson-tx2/third-usb-on-custom-board-not-working-with-jetpack-4-2/post/5330117/#5330117:
--- a/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
+++ b/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
@@ -106,7 +106,8 @@
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
- vbus-2-supply = <&vdd_usb2_5v>;
+ //vbus-2-supply = <&vdd_usb2_5v>;
+ vbus-2-supply = <&battery_reg>;
vbus-3-supply = <&battery_reg>;
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
--- a/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3310-1000-a00-plugin-manager.dtsi
+++ b/sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3310-1000-a00-plugin-manager.dtsi
@@ -263,8 +263,11 @@
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
_overlay_ {
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
- <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>;
- phy-names = "usb2-0", "usb2-1";
+ <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
+ <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
+ <&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
+ <&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>,
+ <&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>;
+ phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0", "usb3-1", "usb3-2
#else
_overlay_ {
@@ -279,7 +282,7 @@
target = <&tegra_xusb_padctl_pinmux_default>;
_overlay_ {
usb3-std-A-port2 {
- status = "disabled";
+ status = "okay";
--- a/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
+++ b/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
#if TEGRA_BOOTARGUMENT_VERSION >= DT_VERSION_2
@@ -196,10 +219,25 @@
vbus-supply = <&vdd_usb1_5v>;
nvidia,oc-pin = <1>;
+ usb2-2 {
+ status = "okay";
+ mode = "host";
+ vbus-supply = <&battery_reg>;
+ nvidia,oc-pin = <2>;
+ usb3-0 {
+ nvidia,usb2-companion = <0>;
+ status = "okay";
usb3-1 {
nvidia,usb2-companion = <1>;
status = "okay";
+ usb3-2 {
+ nvidia,usb2-companion = <2>;
+ status = "okay";
#endif
@@ -230,10 +268,17 @@
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
+ usb3-std-A-port1 {
+ nvidia,lanes = "usb3-0";
+ nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
+ nvidia,oc-pin = <0>;
+ status = "okay";
usb3-std-A-port2 {
nvidia,lanes = "usb3-1";
+ status = "okay";
e3325-usb3-std-A-HS {
@@ -244,7 +289,7 @@
e3325-usb3-std-A-SS {
- nvidia,lanes = "usb3-0";
+ nvidia,lanes = "usb3-2";
--- a/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
+++ b/sources/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
@@ -138,12 +138,12 @@
pinctrl@3520000 {
pinmux {
usb3-std-A-port2 {
+ nvidia,lanes = "usb3-1";
The usb3-1 didn't work, and the usb2-0 didn't work either. If I removed “usb3-1” as:
_overlay_ {
+ phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0", "usb3-2
The usb2-0 would be fine.
Any ideas? Thanks in advance!
