Hello, I use a custom carrier board to load P3310 TX2 device, but the usb3.0 cannot be loaded.
Version: R32.4.4, JetPack4.4, Flushing by Vmware ubuntu18.04.
The steps I have done are listed as follows:
I changed the device tree files as:
hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
vbus-2-supply = <&battery_reg>;
vbus-3-supply = <&battery_reg>;
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
vclamp_usb-supply = <&spmic_sd2>;
avdd_pll_erefeut-supply = <&spmic_sd2>;
and
hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-a00-00-base.dts
ports {
usb2-0 {
status = “okay”;
mode = “otg”;
vbus-supply = <&vdd_usb0_5v>;
nvidia,oc-pin = <0>;
usb2-1 {
status = “okay”;
mode = “host”;
vbus-supply = <&vdd_usb1_5v>;
nvidia,oc-pin = <1>;
usb2-2 {
status = “okay”;
mode = “host”;
vbus-supply = <&battery_reg>;
nvidia,oc-pin=<2>;
usb3-0 {
nvidia,usb2-companion = <2>;
status = “okay”;
usb3-1 {
nvidia,usb2-companion = <1>;
status = “okay”;
Building the kernel under the guidance of Step 1 to 7 of https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/kernel_custom.html#
Flush the kernel to TX2 with
sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
Then I get the output as flush.log (18.7 KB)
I still cannot open USB power of the custom carrier board.
Before this flush, I tried an another way: https://forums.developer.nvidia.com/t/third-usb-on-custom-board-not-working-with-jetpack-4-2/72918/4, under the guidance of eh-steve’s post.
But it also did not work.
I only have one use3.0 port on the custom carrier board.
What shoud I do? I am really a fresher of TX2.
