I’ve designed a custom carrier board for tx2i. But, I am unable to see USB interfaces in ubuntu. kindly assist.
TIA
TIA
What software release are you using ? rel-28 or rel-32?
rel-32
please refer to the usb porting guide and modify the device tree.
I had referred P2597 carrier board schematics for my custom carrier board. There is only one USB 3.0 Port & one USB 2.0 Port in the custom board. The document mentions that by default the carrier board will be config 2. Do I still need to update the device tree?
Even changing the power source requires to change the device tree.
Oh, I am new to this. I have currently designed the carrier board with 1x USB3.0, 1xUSB2.0, 1x UART, 1x ethernet, 2 x 2 lane MIPI CSI2, 1 x RS422, 1 x RS232, 2 X I2C, 1 X JTAG along with auto power on. Could you please assist in configuring the device tree for these interfaces.
TIA
I already shared the document. Read it first and share us what is the part that you cannot understand.
If possible, find a software engineer who is familiar with linux kernel to co-work with you.
ok
As per the requirements of the custom carrier board the following changes were made in the device tree
However, inspite of above changes USB enumeration isn’t happening in Ubuntu. Please find the responses below and kindly assist.
Response for dmesg |grep -i usb
vte@IHS-VTE:~$ dmesg |grep -i usb
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2372e0000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x235840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[ 0.509001] usbcore: registered new interface driver usbfs
[ 0.509033] usbcore: registered new interface driver hub
[ 0.509100] usbcore: registered new device driver usb
[ 0.564419] vdd-usb0-5v: 5000 mV
[ 0.564693] vdd-usb1-5v: 5000 mV
[ 0.865861] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.008238] usbcore: registered new interface driver r8152
[ 1.008268] usbcore: registered new interface driver asix
[ 1.008295] usbcore: registered new interface driver ax88179_178a
[ 1.008320] usbcore: registered new interface driver cdc_ether
[ 1.008346] usbcore: registered new interface driver net1080
[ 1.008374] usbcore: registered new interface driver cdc_subset
[ 1.008399] usbcore: registered new interface driver zaurus
[ 1.008436] usbcore: registered new interface driver cdc_ncm
[ 1.009350] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.009389] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.011814] usbcore: registered new interface driver uas
[ 1.011854] usbcore: registered new interface driver usb-storage
[ 1.011915] usbcore: registered new interface driver usbserial
[ 1.013667] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.016249] usbcore: registered new interface driver xpad
[ 21.391173] usbcore: registered new interface driver usbhid
[ 21.391175] usbhid: USB HID core driver
[ 21.425166] usbcore: registered new interface driver snd-usb-audio
[ 21.603752] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.606799] tegra-usb-cd usb_cd: otg phy is not available yet
[ 21.610467] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.613384] tegra-usb-cd usb_cd: otg phy is not available yet
[ 21.617090] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.452714] tegra-usb-cd usb_cd: otg phy is not available yet
[ 22.457871] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.460711] tegra-usb-cd usb_cd: otg phy is not available yet
[ 22.465241] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.208167] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.214444] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.220618] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.226956] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 52.304480] vdd-usb0-5v: disabling
[ 52.304492] vdd-usb1-5v: disabling
Response for xxd /proc/device-tree/xhci@3530000/phy-names
00000000: 7573 6232 2d30 0075 7362 322d 3100 7573 usb2-0.usb2-1.us
00000010: 6232 2d32 0075 7362 332d 3000 b2-2.usb3-0.
dmesg.txt (65.2 KB)
tegra186-quill-p3489-1000-a00-00-ucm1.dts (485.4 KB)
