USB not working in Jetson TX2 - R32.2
We have developed a custom carrier board for TX2 which utilises USB interface of the SOM. We are currently facing no power to USB issue. Previously, we faced similar issue in L4T R28.2.1 and resolved it by adding following lines in our dtsi file.
    pinctrl@3520000 {
        vbus-2-supply = <&battery_reg>;
However, in R32.2 even the DTB change didn’t help much and we could see no power to the USB.
Quick response in solving issue will be really helpful.
Thanks in advance!
Akash
On r32.2, please check below part in tegra186-quill-p3310-1000-a00-00-base.dts
xhci@3530000 {
    status = "okay";
    phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
        <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
        <&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>;
    phy-names = "usb2-0", "usb2-1", "usb3-1";
xusb_padctl@3520000 {
    status = "okay";
    pinctrl-0 = <&vbus_en0_default_state>;
    pinctrl-1 = <&vbus_en1_default_state>;
    pinctrl-2 = <&vbus_en0_sfio_tristate_state>;
    pinctrl-3 = <&vbus_en1_sfio_tristate_state>;
    pinctrl-4 = <&vbus_en0_sfio_passthrough_state>;
    pinctrl-5 = <&vbus_en1_sfio_passthrough_state>;
    pinctrl-names = "vbus_en0_default", "vbus_en1_default",
        "vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate",
        "vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough";
    pads {
        usb2 {
            lanes {
                usb2-0 {
                    nvidia,function = "xusb";
                    status = "okay";
                usb2-1 {
                    status = "okay";
                usb2-2 {
                    status = "okay";
        usb3 {
            lanes {
                usb3-0 {
                    status = "okay";
                usb3-1 {
                    status = "okay";
                usb3-2 {
                    status = "okay";
    ports {
        usb2-0 {
            status = "okay";
            mode = "otg";
            vbus-supply = <&vdd_usb0_5v>;
            nvidia,oc-pin = <0>;
        usb2-1 {
            status = "okay";
            mode = "host";
            vbus-supply = <&vdd_usb1_5v>;
            nvidia,oc-pin = <1>;
        usb3-1 {
            nvidia,usb2-companion = <1>;
            status = "okay";
You should modify it according to your custom board.
Here is a post for your reference:
https://devtalk.nvidia.com/default/topic/1049988/jetson-tx2/third-usb-on-custom-board-not-working-with-jetpack-4-2/post/5330117/#5330117
Hi DaneLLL,
Is it effective at R32.3.1(Jetpack 4.3)? I modify my dts files,the otg can work well,BUT my USB3.0 cannot work.
Hi CalmCar,
It is effective for r32.3.1. Probably you need some other modification. Please check adaptation guide for programming device tree.
how to resolve same problem on TX2, jetpack4.4,R32.4.3 ??
The patch is for reference:
If your USB lane mapping different, you would need make your own modification by referring to it.
Detail is in adaptation guide.
