USB0 not working at ORIN AGX
I design a mother board for the ORIN AGX.
I’m using 2 USB 3.x.
USB0 is not working when I assamble the ORIN AGX on my board.
When I assamble the same ORIN AGX to the EVB, the USB0 is working.
What might be the problem?
BR
Shmuel
Actually this is kind of a very hard question to answer…because I don’t know your board at all.
If your hardware is different from Orin AGX devkit, then of course default software won’t work.
My question is- Is there a discrete or something in the software the disable the USB0?
I am not sure what do you mean “discrete” here.
Let me use a simple way to describe. The Orin AGX devkit USB0 is using a type C PD controller.
If your design is not based on type C, it will not work.
If your design is type C but not same controller as devkit, it will not work.
If your design is not using same power supply as devkit, it will not work.
So that is why I don’t have answer to your question. I can guarantee the default software is not disabling usb0. But I don’t know how to answer your question because I know nothing about your board.
Please refer to the design guide document and also the usb software porting guide in the L4T developer guide.
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/HR/JetsonModuleAdaptationAndBringUp/JetsonAgxOrinSeries.html?highlight=universal#porting-the-universal-serial-bus
I’m not using USB type C.
Why is it important if it connect to type C or type A (as i’m using)?
Type A port won’t support OTG function.
The hardware design is different so the software configuration will not be same…
So what the configuration I need to configure so the USB0 will work on my board?
Read the document please…
So I need to configure the USB as a device so I can work with Type A?
